visrealm Posted Sunday at 04:17 AM Author Share Posted Sunday at 04:17 AM (edited) @JasonACT has fixed the PICO9918 firmware to make the @TheMole's Alex Kidd water effect work. He found the scanline "register" should continue through 215 before jumping to 255. Here's a video showing it in action: And I've pushed Jason's changes to the repo Edit: Apologies for the poor attempt to play the game. Attempting to play it via screen capture through OBS while reaching for the controller which is too far from the screen I've attached the latest binaries which include a bunch of minor fixes (including this one) and Jason's hot firmware update feature. The files ending with "-sl" have scanlines enabled. The others are "clean". pico9918-pcb-v0-3-gpu-dev-build-0-4-2-2-sl.uf2 pico9918-pcb-v0-3-gpu-dev-build-0-4-2-2.uf2 pico9918-pcb-v0-4-gpu-dev-build-0-4-2-2.uf2 pico9918-pcb-v0-4-gpu-dev-build-0-4-2-2-sl.uf2 Edited Sunday at 04:26 AM by visrealm 5 Quote Link to comment Share on other sites More sharing options...
TheMole Posted Sunday at 05:36 AM Share Posted Sunday at 05:36 AM Awesome, looks exactly like it should! Thanks for testing. 5 Quote Link to comment Share on other sites More sharing options...
visrealm Posted yesterday at 02:39 AM Author Share Posted yesterday at 02:39 AM ArcadeShopper has PICO9918s in stock again. PICO9918 VDP replacement with 200mm cable PICO9918 VDP replacement with 300mm cable I also have more available now in both 200mm and 300mm: PICO9918 from Troy Schrapel on Tindie Same product, same source, same price. 6 Quote Link to comment Share on other sites More sharing options...
M-S Posted yesterday at 06:50 PM Share Posted yesterday at 06:50 PM This is amazing, I didn't expect a Pico would be able to be fast enough to do this, is there a list of current issues and incompatibilities? 1 Quote Link to comment Share on other sites More sharing options...
visrealm Posted 22 hours ago Author Share Posted 22 hours ago 2 hours ago, M-S said: This is amazing, I didn't expect a Pico would be able to be fast enough to do this, is there a list of current issues and incompatibilities? The Pico is a beast. The official TMS9918A + 80Col firmware has no known incompatibilities or issues. The F18A compatibility mode firmware might have some issues with some software, but currently there are no known issues with software it's been tested with. Except where it's very render heavy, you can see minor artefacts (Zaxxon) but still very much playable. 6 Quote Link to comment Share on other sites More sharing options...
