mattbert Posted June 10 Share Posted June 10 Hello! I have a full-sized, upright Atari Star Wars game I bought about a year and a half ago off eBay. I only run it occasionally, when I'm demoing it or playing it. The other day I turned it on and noticed a bit more "electronics" smell than usual, and the audio started glitching on it. I turned it off an pulled the board set and looked at the Sound Board, and noticed a number of leaky capacitors with one area showing some indication of burning. I'm not an electronics wiz but don't mind rolling up my sleeves and am OK with a soldering iron, figuring I'd replace the caps. The ones I ordered were 100uf 35V but they were not the axial type. My question is does anyone know what the tolerance is on the capacitors on the Atari sound board and what they should be replaced with? The ones I purchased were 20% so don't know if that's going to get me into trouble. I'm making the assumption that the non-axial vs. axial is more a matter of form factor than functionality. Thanks in advance for any help you can provide. I'll post a couple associated pictures of the board, what I'm replacing, and what I ordered. Thank you, Matt Quote Link to comment Share on other sites More sharing options...
mr.bill Posted June 21 Share Posted June 21 you would need to add a sleeve to protect the cap from shorting. I would not use those. put axial in. you need to address the corrosion on the board too. you probably should consider this.. https://www.arcadepartsandrepair.com/store/rebuild-kits/game-pcb-cap-kits/atari-star-wars-game-pcb-105c-cap-kit/ replacing this in the transformer https://www.arcadepartsandrepair.com/store/pinball-kits-parts/pinball-parts/atari-big-blue-capacitor-27000uf-25v/ https://www.arcadeshop.com/i/122/atari-big-blue-transformer-cap.htm https://paradisearcadeshop.com/products/atari-big-blue-capacitor-27000μf-25v ar2 rebuild https://www.arcadepartsandrepair.com/store/rebuild-kits/power-supply-rebuild-cap-kit/atari-audio-regulator-2-a035435-02-thru-a035435-06-rebuild-105c-axial-cap-kit/ Quote Link to comment Share on other sites More sharing options...
