doubledown Posted June 17 Share Posted June 17 I decided to finally get around to engineering the addition of a Speed Roller to a custom controller for the ColecoVision. I realize that there are only 3 games that take advantage of the Speed Roller (Super Action Baseball / Football / Soccer), but it was something that I wanted to see if I could do. As this controller isn't "themed" for any specific game, I opted to keep it simple and I just tried to match the aesthetics of the ColecoVision, and the Super Action Controllers, as much as possible. My Speed Roller doesn't "kind of work...similar to the originals"...it is an original Speed Roller from a donor SAC. I pulled the main PCB from a SAC, cut it down to the "necessary" size, removed the "unnecessary" components, and created a mount for it so that it can be installed into a controller enclosure. Details: Enclosure Hammond 1456PH1BKBK, 14” x 8.25”, 10° sloped-top, black powder-coated aluminum, (reinforced, braced, and weighted) All black fasteners (carriage bolts, and low-profile socket-head cap screws), w/ nickel-plated nuts (serrated flange, and nylon-insert locknuts), w/ rear-mounted cord cleats for cable management, & mechanically fastened rubber feet Joystick iL PSM-30 (8-way), w/ Cherry (ZF) D44X MicroSwitches, w/ modified threaded shaft (w/ Sanwa LB-35 ball knob, vermillion), w/ medium centering spring, w/ custom dust boot “simulate” drop mount plate PushButtons iL PSL-C, w/ low-operating force Cherry (ZF) D41X Microswitches, (yellow / orange / purple / blue) PCB w/ Keypad VVG ColecoVision PCB w/ Keypad, (C&K D6C KeySwitches, w/ BTND6 square button caps (black), w/ custom legends) Speed Roller Modified Coleco SAC PCB w/ Speed Roller, w/ custom mount Cable Custom-crimped, 11’ Tensility 9 conductor cable, w/ AMP 9-pin connector Now I can cross "Speed Roller" off the list...enjoy! 1 Quote Link to comment Share on other sites More sharing options...
