How many Users had problems flashing the AGSP firmware - Normal, Custom, I did...?
Flashing AGSP Firmware Problem
4 members have voted
  1. 1. Did you have a problem flashing the Firmware, Normal or Custom Firmware 1.3.0..?
    • Yes - I did have problems flash AGSP firmware 1.3.0 and fixed it with shorting the NAND
    • No - I had no problems with flashing AGSP firmware 1.3.0
    • Yes - I did have problems flash AGSP firmware 1.3.0 and was never able to fix the AGSP after it
      0
  • Please sign in to vote in this poll.
Can a admin or monitor pin this please, its important, thanks... :)
The first time I tried it, it errored and flashed it wrong so had to open the console up and short its NAND then reflashed it and flash OK then.
Anyone else have problems with its firmware and flashing it, it can't be just me...?
**REMEMBER**
You only short the NAND if the AGSP does not boot from the NAND so no lights come on the console when you turn it on and it does not boot.
You short the NAND by its two pin holes above the micro sd card slot by the NAND by using jumper pins on the AGSP Board and then you have to remove the jumper pins before reflashing the NAND of course... :)
You have to press and HOLD DOWN Power and Reset Buttons(Back button next to HDMI) and sort the NAND at the same time by wiggling the pin jumper left and right until you see `One MASKROM Device` in the flashing app then you can remove the jumper pins and flash AGSP, it only flashes on MASKROM Mode not LOADER Mode.
Edited by Spanner
