+yetanothertroll Posted June 25 Share Posted June 25 Yikes, maybe someday I'll finally learn not to try to teach grandma how to suck eggs 😅 Quote Link to comment Share on other sites More sharing options...
Harry Potter Posted June 25 Share Posted June 25 Again, I'm sorry. Maybe it was another model of which I was thinking. BTW, TGB1718, did you get MemXAtari working, even without my cleaning the code? My explanation of the functions should've helped. Quote Link to comment Share on other sites More sharing options...
E474 Posted June 26 Share Posted June 26 Maybe xBIOS is worth having a look at if you're encountering memory constraint issues but still want DOS/disk I/O? There's an example of using it with LZ4 decompression, though I haven't tried it myself, and I don't know if there are 8-bit based LZ4 compression utilities - see: I'm actually messing around with ZX0 decompression on the 8-bit and it works very well, but I do the compression (with Salvador) and assembly on a Linux box. Quote Link to comment Share on other sites More sharing options...
xxl Posted June 26 Share Posted June 26 I suggest using the new version of xBIOS with a built-in decompressor module (LZ4, APL, ZX0 are available) - recently I showed online the use of xB for Atari with 8KB RAM, which resulted in a demo of a game for Atari 400 with 8KB RAM https://forums.atariage.com/topic/366224-game-with-speech-synthesis-for-atari-400-8kb-ram/#comment-5463394 2 Quote Link to comment Share on other sites More sharing options...
E474 Posted June 26 Share Posted June 26 Hi @xxl, Do you mean changing the decompression code in the example from: jsr unlz4 ldx #$02 @ lda colour,x sta COLPF0S,x dex bpl @- ldgfx bmi load_index unlz4 icl 'unlz4.asm' To: jsr dzx0_standard ldx #$02 @ lda colour,x sta COLPF0S,x dex bpl @- ldgfx bmi load_index dzx0_standard icl 'unzx0.asm' (You would have to fix the dzx0_standard being declared in this file and the included file), or is it built in as part of the object code for xBIOS itself? Are there any more sources available, particularly for the demo for the 8K Atari? At the moment I am building for MyDOS, but planning to move over to xBIOS. Does xBIOS support large (16 MB) MyDOS format ATR disk images with sub-directories, and also divisor 0 transfers? The docs/wiki read like it does, but just checking just in case. @whomper Apologies for the slight thread de-rail. Quote Link to comment Share on other sites More sharing options...
xxl Posted June 27 Share Posted June 27 8 hours ago, E474 said: At the moment I am building for MyDOS, but planning to move over to xBIOS. write a private message or open a new topic, just briefly here: yes, it supports the MyDOS 16MB format and divisor 0. What you showed above is a separate decompressor module, I am talking about the built-in decompressor in xBIOS. In short, one of the many possibilities is to use compressed segments in the binary file. example of a segment compressed in a binary file: ldy <fname ldx >fname jsr load_zx0 pla pla continue load_zx0 pla clc adc #1 sta runad pla adc #0 sta runad+1 jsr xBIOS_LOAD_FILE jmp * ; error together with the xBIOS_SET_RUNAD command, this gives huge new possibilities... ; ff ff 00 40 00 00 02 - binary file header ; binary file - can be omitted ; load adr ; compressed ; zx0 (02), apl (01), lz4 (00) or just: (it all depends on you) ldy <fname ldx >fname jmp xBIOS_LOAD_FILE 2 Quote Link to comment Share on other sites More sharing options...
E474 Posted June 27 Share Posted June 27 Hi @xxl, Thanks for the info, I will try it out, maybe a new thread would be better for more questions (when they arise). Quote Link to comment Share on other sites More sharing options...
