CAJoeG Posted Wednesday at 03:57 AM Share Posted Wednesday at 03:57 AM I recently received an Atari 400 with the original power adapter (CO 14319). The system was listed as "no power". I bought it for learning how to repair an Atari 8 bit computer since I have been repairing Commodore computers and peripherals. I'd like to open the system up and check things out before powering it up, but the cartridge port lid is stuck closed. What is the best way to open the system safely (not breaking any parts) when this issue exists? Any help is appreciated! Thank you! Joe Quote Link to comment Share on other sites More sharing options...
Rybags Posted Wednesday at 10:43 AM Share Posted Wednesday at 10:43 AM Normally the lid is spring loaded but the spring can break. Pull the release button forward, if the spring isn't working you should be able to just pry the lid up. Another fault can be the shielding piece inside the lid loses adhesion but I doubt the stuff would liquify and leech down causing the lid to stick. Maybe it suffered a liquid spill which could have caused something to stick. If all else fails you might have to pull the outer shell apart - I think you can disassemble the machine without opening the cartridge door. Quote Link to comment Share on other sites More sharing options...
mimo Posted Wednesday at 10:46 AM Share Posted Wednesday at 10:46 AM 2 minutes ago, Rybags said: I think you can disassemble the machine without opening the cartridge door. I think the lid has to be open to pull the top half of the case off Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted Wednesday at 10:50 AM Share Posted Wednesday at 10:50 AM Never heard of one sticking, sounds like someone has spilt something sticky, like orange juice. I think you'll just have to be really careful, have a look and see if there's any contamination, maybe try get a thin blade in the place where it slides and see if you can ease it Quote Link to comment Share on other sites More sharing options...
ClausB Posted Wednesday at 12:35 PM Share Posted Wednesday at 12:35 PM 1 hour ago, mimo said: I think the lid has to be open to pull the top half of the case off But you can disassemble it upside down, get all the electronics out, and then wash the case parts to destickify the door. 1 Quote Link to comment Share on other sites More sharing options...
ClausB Posted Wednesday at 02:51 PM Share Posted Wednesday at 02:51 PM 2 hours ago, ClausB said: But you can disassemble it upside down, get all the electronics out, and then wash the case parts to destickify the door. Oops, forgot about the 2 power board screws, accessible from the top. Also the keyboard is a bit tricky to remove. Well, if you're careful to dip the door area without getting the power board wet, that might work. Then thoroughly dry it all. 2 Quote Link to comment Share on other sites More sharing options...
Geister Posted Wednesday at 06:33 PM Share Posted Wednesday at 06:33 PM The cartridge port lid must be opened to remove the top of the case. The lid is attached to the aluminum shell not the upper case half. Try spilling some alcohol around the case door to see if it breaks up or lubricates what ever is holding the door shut. 3 Quote Link to comment Share on other sites More sharing options...
CAJoeG Posted Wednesday at 10:52 PM Author Share Posted Wednesday at 10:52 PM Thank you everyone for your prompt replies! I'm going to set aside to 400 for now since I have a large family gathering happening this coming weekend, and then I'm off on vacation for two weeks. As things progress, I'll keep this post updated. Thank you! Joe Quote Link to comment Share on other sites More sharing options...
