WillM Posted July 3 Share Posted July 3 Hi All, I inherited what I believe to be a bricked Rapidus. The first clue is the little orange light is fixed on and doesn't flicker or indicate any activity and the second clue is it boots to a red screen. If I remove it entirely, the 800XL works fine. I've checked voltages, swapped cables, shortened cables, double-checked connections, done continuity checks, replaced chip sockets, and double-checked the extsel/GND/MPD connections both directly to chips (as per the instructions) and touch-points on the PCB and no dice. I also tried it in another 800XL with the same results. If it is bricked, where can I get the .jed file to flash the Xilinx 39SF040? I've trawled the web with no joy, so any help is appreciated. Will. Quote Link to comment Share on other sites More sharing options...
drac030 Posted July 3 Share Posted July 3 (edited) Here you are rapidus_cpld_120916.jed rapidus_rom_054.bin EDIT: these are the factory files. Once the board is restored to operation, you probably will want to update the control menu and the booter, see my website for these (in my sig). Edited July 3 by drac030 3 Quote Link to comment Share on other sites More sharing options...
WillM Posted July 3 Author Share Posted July 3 1 hour ago, drac030 said: Here you are rapidus_cpld_120916.jed 122.64 kB · 3 downloads rapidus_rom_054.bin 512 kB · 1 download EDIT: these are the factory files. Once the board is restored to operation, you probably will want to update the control menu and the booter, see my website for these (in my sig). Thank you very much indeed. Very much appreciated! 👍 Quote Link to comment Share on other sites More sharing options...
