cbmeeks Posted July 6 Share Posted July 6 I can't seem to find this online. Does anyone know the frequency when you start up and press a key? The duration would be helpful too. Thanks! Quote Link to comment Share on other sites More sharing options...
+mizapf Posted July 6 Share Posted July 6 From TI Intern: Sound list accept tone 0475 : DATA >06 0476 : DATA >BF 0477 : DATA >DF 0478 : DATA >FF 0479 : DATA >80 047A : DATA >05 047B : DATA >92 047C : DATA >0A 047D : DATA >01 047E : DATA >9F 047F : DATA >00 This means frequency 1396.91 Hz (~1400 Hz) and duration 166 ms (60 Hz) or 200 ms (50 Hz). (See Edit/Assm manual, page 313ff.) 4 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted July 7 Share Posted July 7 1 hour ago, mizapf said: From TI Intern: Sound list accept tone 0475 : DATA >06 0476 : DATA >BF 0477 : DATA >DF 0478 : DATA >FF 0479 : DATA >80 047A : DATA >05 047B : DATA >92 047C : DATA >0A 047D : DATA >01 047E : DATA >9F 047F : DATA >00 This means frequency 1396.91 Hz (~1400 Hz) and duration 166 ms (60 Hz) or 200 ms (50 Hz). (See Edit/Assm manual, page 313ff.) We need to update it with a little short tune, instead of just a beep. There is also a default HONK sound as well. For bad input. Both the BEEP and HONK you can call in assembly via GPLLNK as detailed in the editor/assembler manual. 1 Quote Link to comment Share on other sites More sharing options...
ColecoFan1981 Posted July 7 Share Posted July 7 (edited) 15 minutes ago, Gary from OPA said: We need to update it with a little short tune, instead of just a beep. There is also a default HONK sound as well. For bad input. Both the BEEP and HONK you can call in assembly via GPLLNK as detailed in the editor/assembler manual. The HONK sound (bad input) sounds like a 220 Hz tone. As for the BEEP sound (startup), it sounds like a 1,397 Hz tone. ~Ben Edited July 7 by ColecoFan1981 Quote Link to comment Share on other sites More sharing options...
cbmeeks Posted July 7 Author Share Posted July 7 Thanks!! Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 8 Share Posted July 8 On 7/6/2024 at 7:11 PM, Gary from OPA said: We need to update it with a little short tune, instead of just a beep. There is also a default HONK sound as well. For bad input. Both the BEEP and HONK you can call in assembly via GPLLNK as detailed in the editor/assembler manual. Speech data saying, "would you like to play a game"? Would be nice 2 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted July 8 Share Posted July 8 5 hours ago, GDMike said: Speech data saying, "would you like to play a game"? Would be nice In my SOB I had it say "ready to start" which was a programmed phrase in the speech synthesizer. 2 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 8 Share Posted July 8 On 7/7/2024 at 2:11 AM, Gary from OPA said: We need to update it with a little short tune, instead of just a beep. No. The beep is imbedded in our brain. Do not disturb. 😉 1 2 Quote Link to comment Share on other sites More sharing options...
Gary from OPA Posted July 8 Share Posted July 8 2 hours ago, sometimes99er said: No. The beep is imbedded in our brain. Do not disturb. 😉 How about an animated startup screen using sprites? 2 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted July 8 Share Posted July 8 9 minutes ago, Gary from OPA said: How about an animated startup screen using sprites? I wouldn't do that either. Once you go beyond the menu system, then anything will go, but before that - nice and calm - recognizable. Many of us are too old for change. 😁 2 2 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted July 8 Share Posted July 8 One of the minimum requirements for emulation: do that beep right. 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 8 Share Posted July 8 59 minutes ago, sometimes99er said: I wouldn't do that either. Once you go beyond the menu system, then anything will go, but before that - nice and calm - recognizable. Many of us are too old for change. 😁 You'd be happy if it squirted Old spice... Ok..me too 3 Quote Link to comment Share on other sites More sharing options...
