+JAC! Posted July 7 Share Posted July 7 Today, I wanted to familiarize myself with playing LZSS tunes. The player source code from DSMC is for mono, so I'd like to add duplication of channels in there is 2nd POKEY (e.g. "double mono"). I checked the original detection routine that comes with MADS and found several things that do not seem 100% correct. https://github.com/tebe6502/Mad-Assembler/blob/master/examples/stereo_detect.asm * ----------------------------- * |second POKEY detect routine| * | answer in A register: | * |$00 - absent $80 - present | - It does not return $00, but can also return $01. - It uses "much" runtime due to the VCOUNT-based loops - There are no labels/comments Here's the proposal I came up with. It should be faster and shorter and correct. Tested so far in Altirra. Feedback is welcome. pokmsk = $10 wsync = $d40a nmien = $d40e audf1 = $d200 audc1 = $d201 audctl = $d208 ;Audio control stimer = $d209 ;Start all POKEY timers irqen = $d20e ;Interrupts enable irqst = $d20e ;Interrupts status skctl = $d20f ;Scan keyboard control .proc detect_stereo ;OUT: <A>=0 (single POKEY), 1 (dual POKEY) offset = $10 ;Address offset of the 2nd POKEY sei lda #$03 ;Reset mask and bit mask for irqst sta skctl+offset ;Reset 2nd POKEY lda #$40 ;Switch channel 1 to 1.77 Mhz sta audctl+offset ldx #0 ;<X>:=0 stx audc1+offset ;Maximum frequency for 1st POKEY timer on 2nd POKEY stx audf1+offset inx ;<X>:=1 stx irqen+offset ;Enable 1st POKEY timer interrupt on 2nd POKEY stx stimer+offset ;Start POKEY timers on 2nd POKEY txa ;<A>:=1 ldx irqen and irqst ;Check if interrupt flag for first timer is set on first POKEY stx irqen ;Reset the bits in irqst cli rts .endp Quote Link to comment Share on other sites More sharing options...
mono Posted July 7 Share Posted July 7 http://atariki.krap.pl/index.php/Programowanie:_Detekcja_stereo Quote Link to comment Share on other sites More sharing options...
tebe Posted July 7 Share Posted July 7 https://github.com/tebe6502/Mad-Pascal/blob/master/lib/misc.pas function DetectStereo: Boolean; assembler; (* @description: Second POKEY detect routine <http://atariki.krap.pl/index.php/Programowanie:_Detekcja_stereo> author: KMK @returns: X = 0 mono @returns: X = 1 stereo *) asm txa:pha ldx #$00 stx $d20f ;halt pokey 0 stx $d21f ;halt pokey 1 ldy #$03 sty $d21f ;release pokey 1 sta $d40a ;delay necessary for sta $d40a ;accelerator boards lda #$ff loop and $d20a ;see if pokey 0 is halted ($d20a = $ff) inx bne loop sty $d20f cmp #$ff bne mono inx mono stx Result pla:tax end; 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted July 7 Share Posted July 7 https://github.com/tebe6502/Mad-Pascal/tree/master/samples/a8/sound/sap_lzss SAP-LZSS Mono, Stereo 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 8 Share Posted July 8 The RANDOM one IMO would probably be simplest and best. The time it takes - does that matter much? You really only need to do it when the program starts and on warmstart. About the only way the user could disable a 2nd Pokey by software method would be a hotkey or Monitor which would be pretty unlikely (real machine) Of course you can change many config items on the fly in emulation but do we need to worry that much? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 8 Share Posted July 8 (edited) 9 hours ago, Rybags said: About the only way the user could disable a 2nd Pokey by software method would be a hotkey or Monitor which would be pretty unlikely (real machine) U1MB firmware controlled stereo upgrades are extremely common these days, although the detection code happens to run in ROM in those circumstances, so should be immune to CPU acceleration (and occuring only on warm/coldstart as you say). Edited July 8 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
+JAC! Posted July 8 Author Share Posted July 8 21 hours ago, Rybags said: The RANDOM one IMO would probably be simplest and best.The time it takes - does that matter much? No, time of course does not really matter, but the VCOUNT loops in the original routine from Seban result of quite some additional initialization/cleanup. From what I written above, I also consider the KMK method the way to go and use it now. Thanks everybody for their input. Quote Link to comment Share on other sites More sharing options...
