lucienEn Posted July 15 Share Posted July 15 Is there an efficient assembler library template code to display an animated sprite? Few options that comes to mind, compute frame offset using multiplication to get next offset, or use fixed mapping table. Also alignment must be compact so I think you might waste some data space depending on line height. 1 Quote Link to comment Share on other sites More sharing options...
glurk Posted July 15 Share Posted July 15 Just a comment, but at least to some degree the effiency of the code would depend upon the height of the sprite. Very efficient code could be written for 16-line heights, for example. For this reason, this type of code is normally purpose-built to optimize for the particular situation. 1 Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 15 Share Posted July 15 processor 6502 include "vcs.h" include "macro.h" char_height equ 9 seg.u Variables org $80 temp .byte digit0 .byte frame_cnt .byte seg Code org $f000 Num .byte #%01110000 ; Zero .byte #%10001000 .byte #%10001000 .byte #%11001000 .byte #%10101000 .byte #%10011000 .byte #%10001000 .byte #%10001000 .byte #%01110000 ; 8 .byte #%11111000 ; One .byte #%00100000 .byte #%00100000 .byte #%00100000 .byte #%00100000 .byte #%00100000 .byte #%10100000 .byte #%01100000 .byte #%00100000 ; 17 .byte #%11111000 ; Two .byte #%10000000 .byte #%01000000 .byte #%00100000 .byte #%00010000 .byte #%00001000 .byte #%10001000 .byte #%10001000 .byte #%01110000 ; 26 .byte #%01110000 ; Three .byte #%10001000 .byte #%10001000 .byte #%00001000 .byte #%01110000 .byte #%00001000 .byte #%10001000 .byte #%10001000 .byte #%01110000 .byte #%00001000 ; Four .byte #%00001000 .byte #%00001000 .byte #%11111000 .byte #%10001000 .byte #%01001000 .byte #%00101000 .byte #%00011000 .byte #%00001000 .byte #%01110000 ; Five .byte #%10001000 .byte #%10001000 .byte #%00001000 .byte #%00001000 .byte #%11110000 .byte #%10000000 .byte #%10000000 .byte #%11111000 .byte #%01110000 ; Six .byte #%10001000 .byte #%10001000 .byte #%10001000 .byte #%11110000 .byte #%10000000 .byte #%10001000 .byte #%10001000 .byte #%01110000 .byte #%00010000 ; Seven .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00010000 .byte #%00001000 .byte #%00001000 .byte #%11111000 .byte #%01110000 ; Eight .byte #%10001000 .byte #%10001000 .byte #%10001000 .byte #%01110000 .byte #%10001000 .byte #%10001000 .byte #%10001000 .byte #%01110000 .byte #%00001000 ; Nine .byte #%00001000 .byte #%00001000 .byte #%00001000 .byte #%01111000 .byte #%10001000 .byte #%10001000 .byte #%10001000 .byte #%01110000 .byte #0 Start: CLEAN_START lda #0 sta digit0 lda #0 sta frame_cnt lda #$0E sta COLUP0 sta COLUP1 Frame: ; VSYNC lda #2 sta VSYNC sta WSYNC sta WSYNC sta WSYNC lda #0 sta VSYNC ldx #36 VSYNC_Loop: sta WSYNC dex bne VSYNC_Loop ; load digit value lda digit0 clc ; multiply by 9 (8+1) asl asl asl adc digit0 ; add digit height offset adc #char_height tax sta WSYNC ; x indexes the offset from the beginning address of the digit bitmap table ; y counts the number of lines until the digit is finished ldy #char_height Disp_num: dex lda Num,x sta GRP0 sta WSYNC dey bne Disp_num lda #0 sta GRP0 ldx #183 VIS_Loop: sta WSYNC dex bne VIS_Loop inc frame_cnt lda frame_cnt and #%00011111 bne No_tick inc digit0 ldx digit0 cpx #10 bne No_tick ldx #0 stx digit0 sta WSYNC No_tick: ldx #28 Overscan_loop: sta WSYNC dex bne Overscan_loop jmp Frame ; Jump Table org $fffc .word Start .word Start Here is a half-decent example, highly simplified. 1 1 Quote Link to comment Share on other sites More sharing options...
lucienEn Posted July 15 Author Share Posted July 15 Thanks very much, that's option1 basically to compute it on the fly which works fine. If I look at Pitfall they use RAM pointer and not sure how that's computed and why they need that is needed. Also weird enough player is 22 pixel height just like Pitfall 2 and filled up to make it 22 which is odd number to compute addresses. Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 15 Share Posted July 15 1 hour ago, lucienEn said: Also weird enough player is 22 pixel height just like Pitfall 2 and filled up to make it 22 which is odd number to compute addresses. Height doesn't matter too much, though it can make things a bit faster. My digit example uses a character height of 9 and multiplies by 9. One way to multiply by 22: load value (1) (t3) clear carry (1) (t5) multiply by 2 (2) (t7) store temp value (2) (t10) multiply by 2 (4) (t12) multiply by 2 (8) (t14) add temp value (10) (t17) add original value (11) (t20) multiply by 2 (22) (t22) a to x (t24) Overall, not too long of an operation, 24 cpu clocks. 1 Quote Link to comment Share on other sites More sharing options...
lucienEn Posted July 15 Author Share Posted July 15 Just now, bent_pin said: Height doesn't matter too much, though it can make things a bit faster. My digit example uses a character height of 9 and multiplies by 9. One way to multiply by 22: load value (1) (t3) clear carry (1) (t5) multiply by 2 (2) (t7) store temp value (2) (t10) multiply by 2 (4) (t12) multiply by 2 (8) (t14) add temp value (10) (t17) add original value (11) (t20) multiply by 2 (22) (t22) a to x (t24) Overall, not too long of an operation, 24 cpu clocks. Got it, probably not a magic number for performance. Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 15 Share Posted July 15 4 minutes ago, lucienEn said: Got it, probably not a magic number for performance. Meh. You have 67 lines to set up your frame, multiplying by 22 takes <1/3 of 1 of those lines 0.47%. Not too costly and a constant time operation. You could speed it up by wasting 2 bytes per picture and multiplying by 24, but you won't gain much and you lose ROM space. Quote Link to comment Share on other sites More sharing options...
Verdant Posted July 16 Share Posted July 16 (edited) 9 hours ago, bent_pin said: Height doesn't matter too much, though it can make things a bit faster. My digit example uses a character height of 9 and multiplies by 9. One way to multiply by 22: load value (1) (t3) clear carry (1) (t5) multiply by 2 (2) (t7) store temp value (2) (t10) multiply by 2 (4) (t12) multiply by 2 (8) (t14) add temp value (10) (t17) add original value (11) (t20) multiply by 2 (22) (t22) a to x (t24) Overall, not too long of an operation, 24 cpu clocks. Nice solution! But you need to move the "clear carry" to just before the first add, otherwise the shifts will clobber it. Alternatively, if we can be sure that we'll never try to multiply by more than 31 (the results break for anything over 11 anyway), we can dispense with the "clear carry" altogether, since the shifts will always set the carry flag to zero. Just for fun I tried a small change: lda start_value asl asl asl (clc) adc start_value adc start_value adc start_value asl tax As counterintuitive as it looks, I believe that it takes the same amount of ROM space (14/13 bytes) and the same number of cycles (24/22), but now we don't need to use a temp value in RAM (or clobber the original value). EDIT: Looking at this again, I realized that if we require a multiplier of less than 12, we can simply do: lda start_value asl asl adc start_value asl adc start_value asl tax I think that this trims it down to 19 cycles and 11 bytes. Edited July 16 by Verdant 2 Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 16 Share Posted July 16 4 hours ago, Verdant said: EDIT: Looking at this again, I realized that if we require a multiplier of less than 12, we can simply do: lda start_value asl asl adc start_value asl adc start_value asl tax I think that this trims it down to 19 cycles and 11 bytes. Nice. That's some quality optimization. I hadn't had a chance to approach this graphwise. Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 16 Share Posted July 16 5 hours ago, Verdant said: or clobber the original value Whoever started using the term clobber was an eloquent genius. 1 1 Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 16 Share Posted July 16 @Verdant I made a graph to do the fastest multiplications. It's a breadth first chart. Turn off line-wrap. multiplier.txt 1 Quote Link to comment Share on other sites More sharing options...
Verdant Posted July 17 Share Posted July 17 (edited) @bent_pin It took me a little while to understand your graph, but it looks very interesting. I think I figured out how to use it, but could you confirm it? Find your desired multiplier on the graph. To traverse the graph at each number, move up one step if you can do so, otherwise move to the next number to the left. Work backwards toward one and make note of each operation (half = double the A register (asl), and one less = add the multiplicand again (adc)). Once you arrive at one, you'll have the fastest list of operations (in reverse order) to perform the multiplication. Edited July 17 by Verdant Quote Link to comment Share on other sites More sharing options...
+bent_pin Posted July 17 Share Posted July 17 3 hours ago, Verdant said: @bent_pin It took me a little while to understand your graph, but it looks very interesting. I think I figured out how to use it, but could you confirm it? Find your desired multiplier on the graph. To traverse the graph at each number, move up one step if you can do so, otherwise move to the next number to the left. Work backwards toward one and make note of each operation (half = double the A register (asl), and one less = add the multiplicand again (adc)). Once you arrive at one, you'll have the fastest list of operations (in reverse order) to perform the multiplication. Pretty much. I start by searching for my target so it's highlighted. Always traveling right before going down, I write down the path's numbers. Then I decide the edge weight as you described +1 = adc, x2 = asl The key to speed it to realize that you will never do to adcs in a row. Then the rest of the graph wrote itself. Took an hour or two, but it was a fun puzzle. Challenge me and see if I made any mistakes. I'll make a demo of use Thursday because I'm off work then. Quote Link to comment Share on other sites More sharing options...
