vicsretrogames Posted July 18 Share Posted July 18 Recently acquired a sears tele game 2600 that someone modded previously. It worked for a few days then it stopped. So me being me I opened it and wow whoever did this I think either kinda knew what they were doing or not at all. I found it kinda funny and weird thats the power in was zipped tied to the board. I'm no expert on any of this so I'm asking the community. Is this worth getting repaired or is it someones headache? Does anyone know a good modding service? Worst case I can get my other 2600 modded. Quote Link to comment Share on other sites More sharing options...
juansolo Posted July 19 Share Posted July 19 (edited) It's eminently repairable. The first thing I'd do is pull all of that crap out and drop a simple mod on there to see what is/isn't working. Using a cable tie to stabilise/strengthen a power jack is perfectly fine by me. I do it on 7800 jack replacements and it, along with how I make the connections and the cut in the back of the case, mean the connection is significantly stronger than stock. As for recommending a repair service, that more depends on your location than anything else. Edited July 19 by juansolo 1 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted July 19 Share Posted July 19 19 hours ago, vicsretrogames said: Recently acquired a sears tele game 2600 that someone modded previously. It worked for a few days then it stopped. So me being me I opened it and wow whoever did this I think either kinda knew what they were doing or not at all. I found it kinda funny and weird thats the power in was zipped tied to the board. I'm no expert on any of this so I'm asking the community. Is this worth getting repaired or is it someones headache? Does anyone know a good modding service? Worst case I can get my other 2600 modded. Whoever did the work didn't bother to install the ESD diode/cap service on the controller ports that really should have been done. Why would that replace the power jack like that though? I mean, 2600 PSUs and 3rd party variants are easy enough to come by that this wouldn't have been needed? As @juansolo stated, it should be repairable and would require starting with removing everything that has been added to get a better look at anything else that might have been modified. I can see by the board layout that is an NTSC 2600? But yeah, take it back to stock condition first to at least make sure it is functioning normally and then go with a replacement AV upgrade form there. If you are in the UK, then the Cleancomp might be the most affordable solution, but if in the US, then I would go with a UAV. Quote Link to comment Share on other sites More sharing options...
techy2600 Posted July 22 Share Posted July 22 Wow, uh, very interesting mod job. But yes this is fixable! I would remove the modded parts first, be careful though, because you don’t know how well these were secured (some look loose). Then start diagnosis from there. Quote Link to comment Share on other sites More sharing options...
Sarsh Posted August 3 Share Posted August 3 Any recommendations for repair service in Minnesota? Quote Link to comment Share on other sites More sharing options...
