Bikerbob Posted July 18 Share Posted July 18 Hey all, I was having trouble getting power to my 400. I think because I know the adapter is good.. and there is the separate PWB board. That I have an issue there. I am going to replace the voltage regulators as per this article. https://retrorepairsandrefurbs.com/2023/02/04/1982-atari-400-repair-restoration But if you have had to trouble shoot this before.. I would love some tips?? James Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 18 Share Posted July 18 2 hours ago, Bikerbob said: Hey all, I was having trouble getting power to my 400. I think because I know the adapter is good.. and there is the separate PWB board. That I have an issue there. I am going to replace the voltage regulators as per this article. https://retrorepairsandrefurbs.com/2023/02/04/1982-atari-400-repair-restoration But if you have had to trouble shoot this before.. I would love some tips?? James first port of call is to check the cart bay door switch is engaging. it won't power up if not. Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted July 19 Author Share Posted July 19 17 minutes ago, Beeblebrox said: first port of call is to check the cart bay door switch is engaging. it won't power up if not. yep.. did that.. I can hear a very faint squeel.. and prior to no power it was taking 2-3 attempts to get a clean boot. I suppose I could try and quickly power it up, see if I am getting +12 and -5v as per the manual. just wonder if I do any damage without a load on it. 1 Quote Link to comment Share on other sites More sharing options...
ClausB Posted July 19 Share Posted July 19 You will need some load on +5V to get a good voltage reading. I use a 25 Ohms 10 Watts power resistor (although 5V across 25 Ohms is only 1 Watt). Quote Link to comment Share on other sites More sharing options...
