DFELD2005 Posted July 20 Share Posted July 20 (edited) I have been comparing the game disk menu features of MyDos 4.53 (using MyPicoDos) vs SpartaDos 3.2g (using MSDOS 4.7). (Using ATR disks with Altirra 4.30 (test versions)) on my Win 10 PC. I found that SpartaDos 3.2g does not appear to execute the CREDIR command with my downloaded and homemade 3.2g ATR disks. (I get the message "File not found".) Today I tried using SpartaDos 3.2f. My downloaded and homemade 3.2f disks are able to execute the CREDIR (and related DIR commands.) (And 3.2f can create a subdir on my 3.2g disks.) I am wondering if I used version 3.2g incorrectly and what are the main differences between 3.2f and 3.2g??? I am pleased to find version 3.2f works great with msdos4.7 for binary load ATR game disks (various sizes). Edited July 20 by DFELD2005 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted July 20 Share Posted July 20 What's new in SpartaDOS version 3.2g ************************************ Version 3.2f could only access drive ID numbers from D1-D8. Now, you can access drive D9. ************************************ A filespec that does not contain a drive number, such as D:TEST, will now default to your currently logged drive on the command line. For example, if you are logged to D4: a filespec of D:TEST will be converted to D4:TEST, instead of D1:TEST as it used to be. This change can be very useful when running programs from different drive numbers, since you can access files with D: and they will automatically be taken from whichever drive the program was was started from. You must now be careful however, to always type D1: when you need to access drive 1 specifically. ************************************ A file will no longer be destroyed when copying it to itself. The DOS checks for this condition, and will report a 'File exists' error. Commands such as: D4:COPY D4:TEST will no longer destroy the file TEST. ************************************ All command line input, including all commands, files, and drive IDs, can now be entered in either lower case or upper case. Lower case was only partially supported in version 3.2f. ************************************ Some commands have been changed, to make them more compatible with the X cartridge, as well as making them easier to type. The following changes have been made: CWD has been changed to CD. CREDIR is now MD (Make Directory). DELDIR is now RD (Remove Directory). Note that with the Remove Directory function now called RD, the RD.COM ramdisk handler needs to be renamed to RM.COM in order for it to work. (This will be the name of the MARS8 compatible driver to be released.) ************************************ There are many additional error messages, so you should no longer see error numbers on the command line. ************************************ A system lock-up bug has been fixed, when the clock wraps from 12-31-1999 to the year 2000. Also, the day of the week offset has been corrected for years after 2000, in the new TDLINE program. We are 5 1/2 years 'ahead of time'<g> ************************************ Program files containing a RUNAD, can now be reentered with the RUN command after returning to DOS. The normal process of saving the starting address for a .COM file into Sparta's internal variables, was disrupted when the file contained a RUNAD address. This has now been fixed, so all program files will behave the same way, whether or not they include the RUNAD address. ************************************ Several changes have been made to the keyboard buffering routines. When holding a key down for auto-repeat, the buffer will not fill up with excess characters that the application program hasn't used yet. There will at most, be one additional character in the buffer during a key repeat. This means that when you release a key, the repeat process stops right away, whereas there could have been many additional keycodes 'stacked up' when using version 3.2f. The key combination Shift-Control-Esc can be used to clear all of the keys currently stored in the buffer. This gives you a way to cancel everything in the buffer when a situation may require you to abort. ************************************ The 1200XL key functions such as DMA off, keyclick toggle, and keyboard lock, now work properly. ************************************ The key buffer NOW DEFAULTS to OFF due to incompatabilities with certain programs. It can always be activated as part of a STARTUP.BAT file using 'key on' (even in lower case), if you would like this feature enabled. ************************************ The AINIT command was removed from the command line. However, the XIO Atari format function can still be used within application programs. ************************************ Even with all these changes, the DOS file size has been reduced by 260 bytes, and the lomem has been dropped 119 bytes. If you do not have a PBI device, your lomem will be at $17A2. Users with a PBI device will find their lomem at $1BA2, since the buffer space uses 1K at lomem, instead of the $D800 PBI area. ************************************ FTe has decided to release a special 3.2 'gx' version that can bring memlo back down to $17A2, by placing the disk buffers under the OS at $C400. This has an added benefit of using a full 2K of buffer space, instead of the 1K space allocated at memlo, and will help the DOS run faster. However, SpartaDOS 3.2 'gx' is NOT COMPATIBLE with BASIC XE, or any other programs using the RAM under the OS from $C400-$CBFF. It is provided for those users who don't require this compatibility, and who would like to have the additional RAM available. NOTE that if you ARE NOT using a PBI device, (such as an MIO or Black Box) you do not need the special 'gx' version, and will already get the 2K buffer space and $17A2 lomem with using the STANDARD 3.2g version. ************************************ SpartaDOS 3.2g and 3.2gx are being released as Shareware on an AS-IS basis. If you do happen to discover any incompatibilites, please don't hesitate to let us know, so that we might be able to fix the problem in any future revisions. This upgrade was made possible by everyone out there who took the time to register 3.2f Thank You! ************************************ If you like what you see, you may register 3.2g by sending $19.95 to Fine Tooned Engineering PO Box 66109 Scotts Valley, CA 95067 This will get you all 3 manuals in addition to the SpartaDOS Toolkit. 1 Quote Link to comment Share on other sites More sharing options...
Ray Gillman Posted July 20 Share Posted July 20 (edited) I went to this link to download 3.2g and booted it (in altirra 4.1 I think?) and ran the MENU program and went to like the 5th menu with CREDIR and created a directory and it seemed to work fine. https://atariwiki.org/wiki/attach/SpartaDOS/SpartaDOS_3.2g_720K.atr If you had a different question or are not using the CREDIR on the menu program but from the command line let me know and catch me up. I see references to 3.2p and 3.3c etc so I would probably compare to the later versions as well (not sure where they are up for download to play with but I digress) Edited July 20 by Ray Gillman Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted July 20 Share Posted July 20 (edited) CREDIR is now MD (Make Directory). and the alias can be re instated. Edited July 20 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
DFELD2005 Posted July 20 Author Share Posted July 20 WOW !!! THANK YOU TO EVERYONE FOR THESE HELPFUL RESPONSES. I DID NOT KNOW ABOUT ALL THE IMPROVEMENTS IN VERSION 3.2G MD, CD, AND RD ALL WORK GREAT IN THE COMMAND LINE. I was not using the MENU.COM program. I was using CREDIR in the command line. THANK YOU!!! Quote Link to comment Share on other sites More sharing options...
