hueyjones70 Posted July 24 Share Posted July 24 I have an 800XL that will not boot a Pac Man, a Pole Position, BASIC, Star Raiders, AtariWriter, ans a QIX cartridge. It will boot Wizard of War and a special Pac Man that is a cart with out a shell. I plan to try it with several more carts but I thought this was a really unusual situation that deserved some exposure. Quote Link to comment Share on other sites More sharing options...
Forrest Posted July 24 Share Posted July 24 (edited) Clean the computer cartridge port with compressed air. Clean the cartridge port with IPA. Edited July 24 by Forrest Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 24 Share Posted July 24 I think some 800 Carts will not work on an XL, did all these work before ? Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 24 Share Posted July 24 Fairly sure all those should work on an XL. At the least when a cart is not compatible you usually get some sign of life then a crash or lockup. I suspect it's probably a physical connection problem. Some boards are thicker than others. Some cart slots don't have adequate spring pressure on the fingers. Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted July 24 Author Share Posted July 24 It must be a bad connection somewhere on the PCB. Today I took arm full of carts to the work table and almost all of them worked. An hour later, back to almost none working. I replaced the cart connector and same thing. Sometimes a particular cart works, sometimes not. I am going to check circuits with a magnifying glass and if I can't find anything it will become a potential parts donor. Quote Link to comment Share on other sites More sharing options...
