thecaver99 Posted July 29 Share Posted July 29 (edited) my atari 800xl seems dead, when powered up and switched on the screen has no output at all(monitor or rf). all chips have there 5v, i have tested nearly all the custom chips in another machine(130XE) only 5 left to remove, socket and test(PIA, Pokey, OS, Basic, MMU) all ram has been tested. would any of the transistors cause a similar issue? Edited July 29 by thecaver99 Quote Link to comment Share on other sites More sharing options...
Peri Noid Posted July 29 Share Posted July 29 You must test the other chips. From my own experience - each of the chips you mentioned can cause such symptoms. I once repaired an XE in which I finally desoldered and socketed all the chips - the lat one was faulty (Pokey) in such way that it was causing a short on one of the address or data lines and the machine was able to ony generate a black screen. No diagnostic tool like SysCheck was able to work. Quote Link to comment Share on other sites More sharing options...
thecaver99 Posted July 29 Author Share Posted July 29 32 minutes ago, Peri Noid said: You must test the other chips. From my own experience - each of the chips you mentioned can cause such symptoms. I once repaired an XE in which I finally desoldered and socketed all the chips - the lat one was faulty (Pokey) in such way that it was causing a short on one of the address or data lines and the machine was able to ony generate a black screen. No diagnostic tool like SysCheck was able to work. i should have them finished this evening for sockets and testing 1 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted July 29 Share Posted July 29 Remember, where possible, never socket more than one chip at a time before testing. There is little point socketing many chips at once, then testing, as if an issue is introduced with socketing one chip, you'll have a hell of a time figuring out the issue. Plus, of course you won't know which chip or chips were the issue. Were possible always put the bad machine's chips into a good known to work machine, avoid the other way around - (or you risk damaging the good chips). I take images of the pcb vias once a chip is removed, then install the socket. This is helped many times where then - if my socketing introduced an issue - I can check connections that are obscurred by the socket. Make sure you clean the area of any debris before installing a socket, and make sure the socket it flat/flush with the board. Last week I had a 800XLF which had a bad Start button. After much checking I found pin 12 of GTIA was not engaging 100% with the socket it was in for whatever reason to do with the leg not connecting with the socket wipe. 4 Quote Link to comment Share on other sites More sharing options...
