TGB1718 Posted July 29 Share Posted July 29 So I created a DOS 2.5 enhanced disk image using Altirra, but when I DIR the disk it says 720 Free Sectors. So I boot a DOS 2.5 disk and format the image which it does and creates an ED disk (so the image under Altirra is the right size). I copy some file to the new disk and also put DOS on it: All looks good with 819 free sectors Leave disk in and boot with SDX U1M in Altirra and this is what I see Only 516 sectors free (so seeing it as single density) Now this is where is gets weird, leave disk in and reboot to DOS 2.5 and this is what I now see It's now a single density disk ???? Not sure if this is an Altirra or SDX issue, might try on real hardware later, but thought I was losing the plot as I was sure yesterday I created an ED disk needed for extra data and today the disk was full, on checking I saw it was now single, so did some checks. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 29 Author Share Posted July 29 Ok, copied those images to an S-Drive-MAX booted to DOS 2.5 and both images came up as ED disks, formatted one and copied files over, wrote DOS and still a nice ED disk. Re-booted (130XE U1M with SDX) and both disk come up as Single Density when doing a DIR so it looks like something SDX is doing, anyone else see this behaviour ? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted July 29 Share Posted July 29 (edited) Nowhere in your steps do I see you making any SDX writes to the disk, SDX will not modify a disk if you do not perform a write to disk function. ED is read only in SDX. It is not SDX at that point but rather a reset/warmstart/coldstart/memory issue of some kind possibly in conjunction with whatever combination of device/emulator you are using. Edited July 29 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
drac030 Posted July 29 Share Posted July 29 58 minutes ago, TGB1718 said: Leave disk in and boot with SDX U1M in Altirra and this is what I see Only 516 sectors free (so seeing it as single density) Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 29 Author Share Posted July 29 32 minutes ago, _The Doctor__ said: Nowhere in your steps do I see you making any SDX writes to the disk, Correct, not doing any writes, just a DIR so shouldn't be getting those results, but I am, hence asking if anyone else see's this issue. The fact it does the same thing under SDX on real hardware although using an S-Drive shows there's something wrong, probably with the way SDX reads ED DOS 2.5 disks Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 29 Author Share Posted July 29 @drac030 thanks for your information, however I didn't do any disk writes, just booted and did a DIR and SDX is not showing the extra sectors. Quote Link to comment Share on other sites More sharing options...
drac030 Posted July 29 Share Posted July 29 3 hours ago, TGB1718 said: just booted and did a DIR and SDX is not showing the extra sectors. Because it supports the DOS 2.5 format read-only. I.e. if you save a file in DOS 2.5, and a part of that file is outside the first 720 sectors, it can be read, but these sectors cannot be written to. This is why they are not shown in DIR - they are not available. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted July 29 Author Share Posted July 29 Ok, makes sense, thanks again Quote Link to comment Share on other sites More sharing options...
