Metal Ghost Posted August 2 Share Posted August 2 (edited) Hi all!  I had a question regarding multi-disc games using Saroo on SEGA Saturn that I wanted to ask before I got all the way through a Disc 1 only to realize I had an issue 😀  So specifically with regards to Panzer Dragoon Saga, I started a new game and got to the first Save point. At that point I saved to both Internal Memory and Ram Cartridge. Then I backed back out to the Saroo menu and tried to load Disc 2. I just wanted to make sure that it would find one or both of the Saves I had created on either the Internal Memory and/or the ‘Ram Cartridge’.  However it just stayed on the Saroo menu with ‘Game Booting’ message at the bottom. Nothing beyond that ever happened.  What I would have expected to happen was that it would at least load and show me my Saves but of course the Saves wouldn’t load. Or do what happened when I loaded Grandia Disc two, which gave a message that no Disc 2 Save was found.  I tried loading Disc 3 as well, but to the same stuck ‘Game booting’ message that never ends.  Has anyone here on AA played through Panzer Dragoon Saga yet on Saroo?  If you load Disc 2/3/4 and don’t have a Save from the end of the previous disc, does it simply not load?  Or do I have an issue with my Bin/Cue files? Edited August 2 by Metal Ghost Quote Link to comment Share on other sites More sharing options...
Metal Ghost Posted August 2 Author Share Posted August 2 One thing I should have noted: I double checked the Disc 2 & 3 CUE files and they both appear to be referencing the correct name for their respective BIN files. Quote Link to comment Share on other sites More sharing options...
Metal Ghost Posted August 6 Author Share Posted August 6 So yea….looks like my issue was bad files!  I got a new version for Disc 2 and it booted up via Saroo just fine!  It saw my Disc 1 Saves (both from Internal Memory and ‘Ram Cartridge’) and when I tried to load told me to put in Disc 1, as it should have. I’m in process of replacing my Disc 3 & 4 Bin/Cue files now (and will probably replace Disc 1 just for good measure) and then I should (hopefully) be all set! 1 Quote Link to comment Share on other sites More sharing options...
