Project "tortoise". Used to work in raptorBasic+
joeyaage
ported over some raptorBasic+ code to JagStudio. This has stumped me.
original raptorBasic+
SUB moveplayer         ' Handles our player movement. Can only be called after 8 frames counted.
    IF (pad1 BAND PAD_DOWN AND player_y%<=((239-24)<<16)) THEN
        RSETOBJ(block_player1%,R_sprite_y,player_y%+(4<<16))
    ENDIF
    IF (pad1 BAND PAD_UP AND player_y%>=(24<<16)) THEN
        RSETOBJ(block_player1%,R_sprite_y,player_y%-(4<<16))
    ENDIF
    IF (pad1 BAND PAD_LEFT AND player_x%=>(16<<16)) THEN
        RSETOBJ(block_player1%,R_sprite_x,player_x%-(4<<16))
    ENDIF
    IF (pad1 BAND PAD_RIGHT AND player_x%=<((351-24)<<16)) THEN
        RSETOBJ(block_player1%,R_sprite_x,player_x%+(4<<16))
    ENDIF
END SUB
tortoise04.abs
JagStudio
    IF (pad1 BAND JAGPAD_DOWN AND player_y%<=((239-24)<<16)) THEN
sprite[block_player1%].y=player_y%+(4<<16)
    ENDIF
    IF (pad1 BAND JAGPAD_UP AND player_y%>=(24<<16)) THEN
sprite[block_player1%].y=player_y%-(4<<16)
    ENDIF
    IF (pad1 BAND JAGPAD_LEFT AND player_x%=>(16<<16)) THEN
sprite[block_player1%].x=player_x%-(4<<16)
    ENDIF
    IF (pad1 BAND JAGPAD_RIGHT AND player_x%=<((319-24)<<16)) THEN
sprite[block_player1%].x=player_x%+(4<<16)
    ENDIF
END SUB
tortoise07.abs
up and down works but left and right wont budge...
The first couple of things I've noticed;
In your left and right you have =< and =>
these would usually be <= and >= like you have for up and down . Although that's how you had them in the RB+ code too. But I'd change them around anyway just to be sure.
Secondly, I assume you set player_x% and player_y% somewhere else in the code? If not then your sprite will only ever move 4 pixels in any direction from whatever those two variables are initialised as.
So if you are setting them elsewhere (perhaps based on the sprite[].X and sprite[].y) then check that code to make sure you are updating the player_x% variable correctly.
Edited by Sporadic
Didn't see that!! I need to read slower...Did make a difference with <= >=, etc.
Also fixed a couple of typos with player_x%, player_y%. Curse copy and paste...
Gold star for Sporadic!!.. thank you...all working now..
