GoldenBubbles Posted August 17 Share Posted August 17 Hello fellow Vectrex owners I need of actual measurements of a Vectrex unit. Many years ago I bought one and I left it displayed at my dessert shop for many years for my customers to play while I prepare their order. It was an eye catcher, it was chained to the table (drilled a hole) so it could not walk away by itself, but my bad luck someone decided to keep it and cut the chain and take it. I have video footage and it ws my busiest day. While I want to get another one I can't fork out a few hundred bucks just for my customers to play so I decded to go another way to remake one if so someone decided to take it again I can make a clone I have Large format 3D printers a some what 3D skills & 3D scanner to aid me. I just need actual 3 measurements XYZ so I can start the process. Thank you anyone who can help and when done I can share the files so you may also make one as a spare if (hopefully not) your case cracks or breaks or you want a Transparent upgrade to you Beloved Vectrex Quote Link to comment Share on other sites More sharing options...
playvectrex Posted August 26 Share Posted August 26 I'm not sure an exact model of the Vectrex will help you, since you still have to fill the inside with very rare components to make it a Vectrex. But there are some models here: https://www.thingiverse.com/search?q=vectrex&page=1 The vectrex stands 362mm tall (when sitting on the rubber feet), and 249mm wide (measured looking down from the top, between the seam lines). Quote Link to comment Share on other sites More sharing options...
