Advise needed for 32k expansion
moije
Hi,All
Today I finally recived this memory expansion
And i want to turn it in a non volatile mem(like minimem).
So maybe with a 3xLR3 holder(4.8v) or 4xLR3(6.4v)with 2 diodes in serial.
I also need a switch to disable 32k without loosing data in it(don't want XB to Write on it).
I wrote a prog that run from minimem and gives me the ability to store multiple files in expmem2 from expmem1(buffer).
I was wondering if someone could give me tips for soldering and how much power it will need.
Thanks in advance.
Here is the info direct of  "The Brewing Academy Website"
It runs off of +5v, using about 5-10mah. There is one configuration jumper to either take power from an external 5.5/2.1mm tip-positive 5.0 VDC power supply, or the TI-99/4A sideport. It will work with your Speech Synthesizer installed IF you use an external power supply (available separately) OR modify your speech synthesizer to supply power at pin #1.
The power consumption is pretty low if the bus buffer and other logic chips are HCT type.
It has a power supply connector on the back. Instead of batteries, you could just leave it powered. When I built them there was a 3 pin header that controlled if the +5v came from the TI expansion port, or from the power supply. So you could also tap in there for battery, the center pin feeds the board, the outer 2 are the different supplies.
To disconnect the circuit from the bus, and to allow an alternative memory expansion, I would wire a disconnect switch to the _245's enable feed, and a 20k pull-up to the same pin. When the switch is closed, the feed can override the pull-up, the pull-up is in full control when the switch is open.
