alsp Posted September 1 Share Posted September 1 Hi Guys! Created one more drive for 8-bit Atari - lets name it xDrive. Goal is to create cheapiest and smallest drive emulator with wide range of functionality. Hardware: Based on ESP32-C3 with Risc-V processor; 4Mb Flash; 320K RAM; SD card; WiFi/Bluetooth capable; Size: 40mm x 30mm x 13mm; No buttons at all; Software: Refactored SDrive FW from SDrive2 ported and working; Fujinet - ported - not enough RAM to work with FAT/WiFi/Bluetooth as-is - thinking what to do - optimize FW or create one more revision based on ESP32-S3; Updating thru USB; HW will be fully opensource in 1 - 2 month - need to clean it up. Some photos attached. Any thoughts? 15 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted September 1 Share Posted September 1 The project looks nice, but it would be the same as the other devices like sdrive, sdrive-max, SDrive-Simple-II, SDRIVE MINI. I wonder as they all use the same firmware there are several details in the emulation or you solved them ? Quote Link to comment Share on other sites More sharing options...
woj Posted September 1 Share Posted September 1 50 minutes ago, ascrnet said: there are several details in the emulation Can you give some (all?) concrete examples? I am nearing having the complete base code for my device and could use something to make it better / different 😉 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted September 1 Share Posted September 1 3 hours ago, woj said: Can you give some (all?) concrete examples? I am nearing having the complete base code for my device and could use something to make it better / different 😉 The enhanced density (1040 sectors) used by DOS 2.5 is not implemented, only the simple density (720 sectors) works correctly, that's what I remember for the moment, the other points you can read in the corresponding threads of each device. 😉 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted September 2 Share Posted September 2 Hard to see from your photo's, is it a "through" port to allow other devices on the SIO bus. Will it work with other devices on the bus i.e. some S-Drive MAX need a small modification to allow this. Quote Link to comment Share on other sites More sharing options...
alsp Posted September 2 Author Share Posted September 2 16 hours ago, ascrnet said: The project looks nice, but it would be the same as the other devices like sdrive, sdrive-max, SDrive-Simple-II, SDRIVE MINI. I wonder as they all use the same firmware there are several details in the emulation or you solved them ? FW is fully refactored - i.e. almost written from scratch , but bugs can exists of course 😃 3 hours ago, TGB1718 said: Hard to see from your photo's, is it a "through" port to allow other devices on the SIO bus. Will it work with other devices on the bus i.e. some S-Drive MAX need a small modification to allow this. Board itself support pass-thru, but case on the photos - not. Plan is to make both variants - simple and pass-thru 1 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted September 2 Share Posted September 2 7 hours ago, alsp said: FW is fully refactored - i.e. almost written from scratch , but bugs can exists of course 😃 Perfect. 😉 Tell us what devices will it emulate: floppy disk drives, tape decks, modems, printers? Quote Link to comment Share on other sites More sharing options...
alsp Posted September 2 Author Share Posted September 2 1 hour ago, ascrnet said: Perfect. 😉 Tell us what devices will it emulate: floppy disk drives, tape decks, modems, printers? For now floppies, includes atx and tapes, but for the tapes configuration tool not yet finished - only manual config file editing. Quote Link to comment Share on other sites More sharing options...
sanny Posted September 4 Share Posted September 4 Nice. I'm definitely interested since it uses a RISC-V 🙂 Quote Link to comment Share on other sites More sharing options...
