EAdmund Posted September 3 Share Posted September 3 Hi, My Atari 800 recoverd after 30 years from my parents loft works Ok(...) with RF (sound and pic), and the pic works Very well on the 5 pin din output. But the sound is (almost) totally muted. On Star Raiders, you can just (and I mean just) about make out that somthing is changing when you fire photons. Any ideas where the problem might be???? Regards Eadmund Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 3 Share Posted September 3 amplifier circuit, and check it's speaker as well. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 3 Share Posted September 3 3 hours ago, _The Doctor__ said: amplifier circuit, and check it's speaker as well. I have an identical issue, but I am 99.9% sure it is caused by the power board rather than the main board. See here: Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 3 Share Posted September 3 (edited) could be, the connections that pass through sometimes corrode or form a patina, but the primary thing most people do is a clean and re seat of all connectors and chips which normally corrects or ferrets out the issues Edited September 3 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 3 Share Posted September 3 (edited) 36 minutes ago, _The Doctor__ said: could be, the connections that pass through sometimes corrode or form a patina, but the primary thing most people do is a clean and re seat of all connectors and chips which normally corrects or ferrets out the issues I agree and that would be my normal route. However, in this instance I'd tried two different 800 mainboards with the suspect power board in question, and then another power board with the same two mainboards. The faulty power board had low volume output when paired with each mainboard in turn, yet the other power board with no issues worked fine when paired with the same two mainboards, with normal volume. So the issue is with the powerboard in question. On the suspect power board I'd checked the pin connector array which connects the mainboards to the power boards and no bad connections. Mystery. There are no ICs on the power boards, just passive components. For now I'd just discarded the faulty power board and replaced it with the working one. Edited September 3 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
