KJ4860 Posted September 16 Share Posted September 16 Hello! Long time no speak - wondering if anyone else has had luck getting their jcd backup of this title to work? I've dumped mine to cue/bin and converted, no dice; converted to cdi then jcd, no dice. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted September 17 Share Posted September 17 3 hours ago, KJ4860 said: Hello! Long time no speak - wondering if anyone else has had luck getting their jcd backup of this title to work? I've dumped mine to cue/bin and converted, no dice; converted to cdi then jcd, no dice. Yes, works perfectly, right down to the constant click noise 1 Quote Link to comment Share on other sites More sharing options...
KJ4860 Posted September 17 Author Share Posted September 17 2 hours ago, CyranoJ said: Yes, works perfectly, right down to the constant click noise Drats. I have a few different SD cards on the way incase that is the issue. Otherwise, ive already tested with four cards on hand. Any tips? Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted September 17 Share Posted September 17 2 hours ago, KJ4860 said: Drats. I have a few different SD cards on the way incase that is the issue. Otherwise, ive already tested with four cards on hand. Any tips? Just the usual: format the card and put the CD files on first, unfragmented. Quote Link to comment Share on other sites More sharing options...
KJ4860 Posted September 17 Author Share Posted September 17 Got it working. Of note to anyone that may run into compatibility issues with dumps: retain image names when converting, as for some reason, assigning a different output name when going from bin/cue to cdi seems to be the hold up in my case. Thanks CyranoJ! 1 Quote Link to comment Share on other sites More sharing options...
