KanedaFr Posted 17 hours ago Share Posted 17 hours ago Hi, I read on some topics on AA what there is a "known" bug on scaling. Since emulators are able to render this bug, could someone explain me this bug ? I'm trying to stack 2x scaled objects on screen but I have +1, +2 or +3 to ypos to avoid empty line. So I'd like to know if I could use scaling or just forget about it and scale bitmap data outside of the Jaguar... Thanks Quote Link to comment Share on other sites More sharing options...
42bs Posted 5 hours ago Share Posted 5 hours ago (edited) Scaling works perfectly. The Jaguar boot is a scaled object. JagNiccc2000 uses a few of them. Scaled and mirrored. Edited 4 hours ago by 42bs Quote Link to comment Share on other sites More sharing options...
KanedaFr Posted 4 hours ago Author Share Posted 4 hours ago (edited) I have exactly the same issue that in this thread -> Is it JagStudio related ? Edited 4 hours ago by KanedaFr Quote Link to comment Share on other sites More sharing options...
42bs Posted 3 hours ago Share Posted 3 hours ago 16 minutes ago, KanedaFr said: Is it JagStudio related ? I'd say only with respect to you using JS and did something wrong Maybe show your code and/or a picture of the result. Quote Link to comment Share on other sites More sharing options...
KanedaFr Posted 3 hours ago Author Share Posted 3 hours ago It's hard to show code w/o filling a full page since I'll need to share rapinit.s I'll try to isolate the problem on one sample project and share the zip + binary Quote Link to comment Share on other sites More sharing options...
42bs Posted 3 hours ago Share Posted 3 hours ago Just now, KanedaFr said: It's hard to show code w/o filling a full page since I'll need to share rapinit.s I'll try to isolate the problem on one sample project and share the zip + binary The part of the object list should be enough. But JS experts might need only a look into your rapinit.S to pin-point the problem. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted 3 hours ago Share Posted 3 hours ago When using a scaled object set the bitmap pointer address to the address of the bitmap +1 line worth of data. This is fully documented in the... documentation. [edit] or it could be -1 line Too tired to go check, but its one of those. Quote Link to comment Share on other sites More sharing options...
KanedaFr Posted 3 hours ago Author Share Posted 3 hours ago I use a dynamic list : 20 instances of the same object, scaled x2 (64), edited by code so it's not that obvious to debug just with a rapinit.s Something like: object2.y_ = 240-(scale*object2.height) object1.y_ = 240-(scale*object2.height)-(scale*object1.height) Quote Link to comment Share on other sites More sharing options...
KanedaFr Posted 3 hours ago Author Share Posted 3 hours ago 3 minutes ago, CyranoJ said: When using a scaled object set the bitmap pointer address to the address of the bitmap +1 line worth of data. This is fully documented in the... documentation. Oh no!!! not again...:((( What the hell did I miss...?! I only saw The object must be on a 32 byte boundary in 64 bit RAM. which I was trying to debug Quote Link to comment Share on other sites More sharing options...
KanedaFr Posted 3 hours ago Author Share Posted 3 hours ago (edited) ARG !!!!!! Please note that for scaled bitmap objects, HEIGHT should actually be the bitmap height -1. So, for exemple, 16 if not scaled, but 15 if scaled ? and what about framez ? and vbox ? Edited 3 hours ago by KanedaFr Quote Link to comment Share on other sites More sharing options...
Seedy1812 Posted 3 hours ago Share Posted 3 hours ago If you are passing the same values in for both scaled sprites ( different x and y - on screen ) then they should be drawn the same. The pictures you shown from another thread has a shift in the x whilst you talk about the y. Chances are its the SBMO Remainder Quote Link to comment Share on other sites More sharing options...
