whomper Posted Thursday at 11:45 AM Share Posted Thursday at 11:45 AM Hi, I've been happily modding my 800XL only to find out that (perhaps) after many times opening and closing the case, the keyboard ribbon cable is now causing issues. It has visible sign of a dent that may have broken a few traces. Wiggling it a bit creates proper connection for a few keys (grey ones to be precise) only to find out it is not stable. Is there a replacement ribbon cable I can use or some other method of properly securing connection? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Thursday at 11:56 AM Share Posted Thursday at 11:56 AM 3 Quote Link to comment Share on other sites More sharing options...
Overange Posted Friday at 07:01 AM Share Posted Friday at 07:01 AM If its these where you can make your own replacement ribbon, by soldering in a ribbon cable then I have uploaded the pcb design to PCBway https://www.pcbway.com/project/shareproject/Atari_Keyboard_Adapter_pcb_ideal_to_make_replacement_ribbon_0bbe0398.html 2 1 Quote Link to comment Share on other sites More sharing options...
+kheller2 Posted Friday at 11:10 AM Share Posted Friday at 11:10 AM How about a picture of the problem cable section? The plastic film ones can usually be cut with scissors, to a point. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted Friday at 02:22 PM Share Posted Friday at 02:22 PM 2 hours ago, kheller2 said: How about a picture of the problem cable section? The plastic film ones can usually be cut with scissors, to a point. indeed. You can cut up to 10mm (from memory) from the clear plastic type. Just don't cut more than you have to as you'll leave it too short. Also, you may need to peel off the rigid plastic backing on the edge to reapply it once the cable is shortened. The rigid plastic strip helps you to push the ribbon into the 24 pin connector. As mentioned above post an image so we know what you have and what state it's in. Sometimes the pins on the connector can also cause an issue. Been there 100's of times over the years. Quote Link to comment Share on other sites More sharing options...
whomper Posted yesterday at 05:41 AM Author Share Posted yesterday at 05:41 AM Here are pics of the ribbon cable. Playing to find the fault I had broken a few traces on the side connected to my keyboard so I spent yesterday evening peeling off insolation and soldering it back into the keyboard end (naturally, had to take that apart with all the little thingies....). Now I'm back with the START button and Led giving me grief... Quote Link to comment Share on other sites More sharing options...
nasty niff Posted 21 hours ago Share Posted 21 hours ago Or do something like this , care of @flashjazzcat 1 Quote Link to comment Share on other sites More sharing options...
Skywise Posted 15 hours ago Share Posted 15 hours ago 5 hours ago, nasty niff said: Or do something like this , care of @flashjazzcat Which video was this from? If I start having issue I might want to do this. Quote Link to comment Share on other sites More sharing options...
nasty niff Posted 15 hours ago Share Posted 15 hours ago 26 minutes ago, Skywise said: Which video was this from? If I start having issue I might want to do this. "show me where he hurt you" 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted 9 hours ago Share Posted 9 hours ago 5 hours ago, nasty niff said: "show me where he hurt you" Right where the mylar meets the PCB. Such a tender spot. Quote Link to comment Share on other sites More sharing options...
Skywise Posted 7 hours ago Share Posted 7 hours ago Found one of them, not the same one but gives the general idea. Quote Link to comment Share on other sites More sharing options...
