Fabrizio Caruso Posted October 7 Share Posted October 7 All my homebrewed games are in EA5 format (multiple files per game). I would like to run then on a browser and make them available to everyone by providing links to js99er with a link to a .bin e.g., https://js99er.net/#/?cartUrl=http://tigameshelf.net/Files/Emu/bnp_8.bin js99er online emulator can read cartridge files in .bin format (whatever it is). Is there a tool to do the conversion from EA5 to a cartridge format that js99er can digest? Ideally I would need a scriptable tool that I can include and invoke automatically in my build-chain. Is there such a scriptable tool? Otherwise I will make do with a manual tool. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted October 7 Share Posted October 7 There are 2 GUI tools that will pack a set of EA5 files into a module with a ROM loader. Fred Kaal's 'module creator' over at hexbus.com/ti99geek. The second is classic99, under the debug tools there is a make module menu item, exact location and docs are in the PDF. For scriptable solutions, you can build a ROM loader, and DD the parts together into a .bin. understand the sample code over here http://www.stuartconner.me.uk/ti/ti.htm#bank_switching 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted October 7 Share Posted October 7 (edited) I use a Java tool that can be invoked like this: java -jar ea5tocart.jar bin\pinball "PINBALL 99" Where pinball is the name of the first E/A#5 file, which must be in TIFILES format. ea5tocart.jar Edited October 7 by Asmusr 3 1 Quote Link to comment Share on other sites More sharing options...
+MarkB Posted Thursday at 07:34 AM Share Posted Thursday at 07:34 AM There are some utilities in the elfutils directory of the GCC installation. These are elf2cart, elf2ea5 and ea5split. I didn't write these - I inherited them from somewhere. But it should be possible to write a simple standalone command line tool to convert ea5 to cart by reading the source for these utils. If you do create a ea5 to cart util it could be a useful addition to these tools to include with gcc. Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted 7 hours ago Author Share Posted 7 hours ago (edited) @Asmusr thanks! The image works fine with Classic99 but not with JS99er (when loaded though the URL cartUrl parameter). Edited 4 hours ago by Fabrizio Caruso Quote Link to comment Share on other sites More sharing options...
Asmusr Posted 6 hours ago Share Posted 6 hours ago 1 hour ago, Fabrizio Caruso said: @Asmusr thanks! The image works fine with Classic99 but not with JS99er. Please post an example of an image that doesn't work in JS99er. Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted 4 hours ago Author Share Posted 4 hours ago (edited) @Asmusr, sorry I need to correct what I wrote or make it clearer. The image may work with JS99er. It just does not work if I try to load it through the URL parameter cartUrl (https://js99er.net/#/?cartUrl=), e.g., https://js99er.net/#/?cartUrl=https://github.com/Fabrizio-Caruso/CROSS-LIB/releases/download/trexBETA/XTREX18.bin or https://js99er.net/#/?cartUrl=http://github.com/Fabrizio-Caruso/CROSS-LIB/releases/download/trexBETA/XTREX18.bin By the way, I am using ea5tocart in my framework. I would like to include it. Who should I thank for the tool other than you for pointing it out? Are you the author? Edited 4 hours ago by Fabrizio Caruso Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted 3 hours ago Author Share Posted 3 hours ago @Asmusr the cartridge does not work even if I just use the Load Cart button. It is a 32K cartridge which assumes there are 32K of available RAM. I suppose it loads everything into RAM at startup and runs everything from RAM. I don't even know how this is possible with bank switching. Quote Link to comment Share on other sites More sharing options...
RickyDean Posted 2 hours ago Share Posted 2 hours ago @Fabrizio Caruso it works with the Load cart function, of course I don't know about the URL capability. Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted 2 hours ago Author Share Posted 2 hours ago (edited) @RickyDean Yes, indeed it works. I may not remember well. @Asmusrhave you just fixed the load something? Load cart works for me. Loading with cartUrl does not (yet). Edited 2 hours ago by Fabrizio Caruso 1 Quote Link to comment Share on other sites More sharing options...
Fabrizio Caruso Posted 2 hours ago Author Share Posted 2 hours ago @RickyDeanBy the way, I will re-release all my 9 games soon. They now work well and have been improved. I will make them available in both EA5 and .bin (cartridge) format. 2 Quote Link to comment Share on other sites More sharing options...
