General maintenance and repair questions/procedures inquiry
polargeek
I'm hoping someone can help answer a few Colecovision repair questions.  I am trying to figure out the general consensus on necessary and/or recommended repairs or preventative maintenance.
I currently have five units on my bench that need some work. All in various different states of function.
On all of them:
I've already disassembled and cleaned the power switches.
Adjusted the audio pot for two units that had only static for audio
Now the questions
1. If I'm replacing bad controller chips with the units from Console5 that have integrated ESD protection. Do I also want the Ruggers Customs ESD boards? Or is that overkill or even potentially problematic?
2. Is recapping these units strictly necessary like some other vintage systems? Or is it just good practice in general, given their age?
3. Is there something I'm missing?
Thanks
ICs with built-in ESD are typically level one protection of 2kV. That my seem like a lot, but typical static buildup walking across the floor can be upwards of 12kV or 20kV opening a simple plastic bag. Keep in mind, it takes 10kV before you can even see a spark touching a doorknob in the winter. TVS diode protection, like on the Ruggers boards are typically around 20-30kV of protection.
It is perfectly safe to use both at the same time in this situation, but I just recommend replacing the controller ICs with regular replacements and use something like the Ruggers ESD board. 2kV is simply not enough protection to be considered a true permanent fix in this application.
