uosipa llamxew Posted November 26, 2003 Share Posted November 26, 2003 (edited) ... Edited September 22, 2005 by mojofltr Quote Link to comment Share on other sites More sharing options...
Xot Posted November 26, 2003 Share Posted November 26, 2003 A power supply. And if it's TRULY an "original", the Combat will be in a gatefold box. Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted November 26, 2003 Share Posted November 26, 2003 A power supply. And if it's TRULY an "original", the Combat will be in a gatefold box. The power supplies would be grey instaid of black also. @mojofltr - Your lucky you didn't win that other auction, it was way too high already. Quote Link to comment Share on other sites More sharing options...
uosipa llamxew Posted November 27, 2003 Author Share Posted November 27, 2003 (edited) ... Edited September 22, 2005 by mojofltr Quote Link to comment Share on other sites More sharing options...
DeAnges Posted November 27, 2003 Share Posted November 27, 2003 aside from the huge hole in the bottom of your vcs, is there any damage to the electronics? Quote Link to comment Share on other sites More sharing options...
Room 34 Posted November 27, 2003 Share Posted November 27, 2003 @mojofltr - Your lucky you didn't win that other auction, it was way too high already. It was definitely way too high! I'm kind of hard up right now though. The VCS I have has a gigantic hole in the bottom (don't ask), and my Gemini is in dire need of a soldering job. Both are in kind of crappy condition. I am kind of worried about buying a used VCS on Ebay anyways. It might look pretty, but you never know what kind of abuse it has taken on the inside. That vader was still sealed (drool), which would almost guarantee perfect condition on the inside. Ah well - guess I saved 250 bucks. ((sniff)) I have purchased several consoles on eBay, including three 2600s, and all have worked perfectly except the one that the seller said did not work. (And that one even does SORT OF work.) The VCS was a hardy piece of equipment. You're far less likely to run into a flaky one than you are with the NES, for instance. Quote Link to comment Share on other sites More sharing options...
Rob Mitchell Posted November 28, 2003 Share Posted November 28, 2003 The original 1977 consoles included the original 5 spring design joysticks which feature the top of the stick hex name disc (which almost always fell off during gameplay). The original 1977 switchbox was the square one with the 75 ohm cable input as well as the 300 ohm input. It said "GAME" with the switch. Rob Mitchell, Atlanta, GA Quote Link to comment Share on other sites More sharing options...
jskirwin Posted December 2, 2003 Share Posted December 2, 2003 Familiarize yourself with the heavy sixer. Some Ebay sellers will tell you exactly what the unit looks like. About a quarter of the units I've seen out there are NOT true Heavy Sixers. If you have any doubt, don't bid - or contact the seller and have him/her read the sticker on the bottom of the unit. Quote Link to comment Share on other sites More sharing options...
