+johnnywc Posted January 3, 2004 Share Posted January 3, 2004 Hello all, I just got my 5200 vid mod in the mail and can't wait to hook it up. I had a few questions I was hoping someone out there could answer before I proceed... 1) does the 5200 produce stereo sound? If so, could the single stereo phono connector be replaced with 2 RCA jacks for stereo sound? Would this be as simple as soldering the red wire to a jack, white wire to the other jack, and ground to both? 2) the three leads coming off of the video mod are composite, luma and chroma. Could the luma and chroma be connected to a standard s-video jack for s-video? I know there are 4 pins - is it as simple as soldering the luma and chroma to pins 3 and 4 (top) and the common ground to pins 1 and 2? 3) here's the dumb question: I really want to test this tonight but I don't have the proper drill bit. Once a wire is put in the molex connector, can it be removed? If so, how? Thanks in advance!!! [/url] Quote Link to comment Share on other sites More sharing options...
Dantaipan Posted January 4, 2004 Share Posted January 4, 2004 3)Once a wire is put in the molex connector, can it be removed? If so, how? I did this by accident and would advise against it if possible. Quote Link to comment Share on other sites More sharing options...
+Allan Posted January 4, 2004 Share Posted January 4, 2004 3)Once a wire is put in the molex connector, can it be removed? If so, how? I did this by accident and would advise against it if possible. Ditto! I did this also and was able to get it out but I could see how if I wasn't very careful I could break. Be patent and wait to do it right. Allan Quote Link to comment Share on other sites More sharing options...
