robcatron Posted January 25, 2004 Share Posted January 25, 2004 I know, I know, I should remember how to do this, but I can't! I just got my ST out of mothballs, and would like to install some the those great adventure games to my hard drive. How can I select all files from within a GEM window? I was thinking that on my falcon, you pressed the "E" key, but this doesn't work on my 520STFM (modified to 4 megs). I know I can hold the shift key down, use the rubber band feature, but how can I select every file, then copy over? thank you very much, Rob Quote Link to comment Share on other sites More sharing options...
+Sauron Posted January 25, 2004 Share Posted January 25, 2004 Under the File menu, is there an option to select all files? Quote Link to comment Share on other sites More sharing options...
robcatron Posted January 25, 2004 Author Share Posted January 25, 2004 Under the File menu, is there an option to select all files? No-- not an option on this version of tos anyway Quote Link to comment Share on other sites More sharing options...
Gregory DG Posted January 25, 2004 Share Posted January 25, 2004 If you are doing Floppy to Hard Disk, can't you drag the Floppy disk icon to whatever directory on the HD you want? Maybe that'll do it... Quote Link to comment Share on other sites More sharing options...
+Sauron Posted January 25, 2004 Share Posted January 25, 2004 If you are doing Floppy to Hard Disk, can't you drag the Floppy disk icon to whatever directory on the HD you want? Maybe that'll do it... Duh, I didn't even think of mentioning that! I should have, too, I've been doing quite a bit of that with my Falcon. Quote Link to comment Share on other sites More sharing options...
robcatron Posted January 26, 2004 Author Share Posted January 26, 2004 If you are doing Floppy to Hard Disk, can't you drag the Floppy disk icon to whatever directory on the HD you want? Maybe that'll do it... Duh, I didn't even think of mentioning that! I should have, too, I've been doing quite a bit of that with my Falcon. Still, though, I don't think this is the most versatile way -- for instance, if you have three floppies with, say an SSI folder (I think Questron was like that), I'm pretty sure that this wouldn't work, as I think everytime it would simply overrite the SSI disk. I just want to be able to do to the window, select all (I think on the Falcon, it was "E" - sort of like CTRL-A in windows) oh, well, maybe no way. perhaps only in newer versions of TOS Quote Link to comment Share on other sites More sharing options...
+Sauron Posted January 26, 2004 Share Posted January 26, 2004 Still, though, I don't think this is the most versatile way -- for instance, if you have three floppies with, say an SSI folder (I think Questron was like that), I'm pretty sure that this wouldn't work, as I think everytime it would simply overrite the SSI disk. I just want to be able to do to the window, select all (I think on the Falcon, it was "E" - sort of like CTRL-A in windows) oh, well, maybe no way. perhaps only in newer versions of TOS I know what you mean, plenty of the games I've copied over to my Falcon's HD have been plenty tedious, even with being able to select all files with one shot. Have you considered upgrading your version of TOS? Quote Link to comment Share on other sites More sharing options...
Gunstar Posted January 26, 2004 Share Posted January 26, 2004 The ST's owner manual says to hold down [shift] while selecting icons to select multiple icons, this way they don't have to be grouped together or visible in the window like with the rubber-band "lasso" way...if a file is already selected, shift-left click will disable too, so if you "lasso" a bunch of files but want one in the middle deleted, then you use both ways to accomplish this task. I have TOS 1.0-1.2 (somewhere in there) and this works fine. But at least with the [shift] key you can scroll through the window and select all the files, since there seems to be no way to automatically do it with older TOS versions... I always drag a folder or drive icon itself to get every file at once in a directory. Quote Link to comment Share on other sites More sharing options...
Goochman Posted January 26, 2004 Share Posted January 26, 2004 I think you can use the CTRL key to deselect certain files as well. Quote Link to comment Share on other sites More sharing options...
Major Havoc 2049 Posted February 3, 2004 Share Posted February 3, 2004 1. Open your new destination folder/window and minimize it and drag it down to the lower right corner of the screen. 2. Open up the folder/window that you want to copy the files out of and put it in the upper left corner of the screen. 3. Place the mouse pointer slightly above and to the left of the files you want to copy. 4. Click and hold the left mouse button and drag it over the files you want to copy, in order to highlight them. 5. Drag the highlighted files over to the new folder. When copying games that have multiple disks and some of the same file names on each disk, it will ask you if you want to overwrite the file, just select "Skip" and it will go to the next file to copy. Is this what you want to do? Quote Link to comment Share on other sites More sharing options...
Atari_Owl Posted February 3, 2004 Share Posted February 3, 2004 CTRL is to select MOVE instead of COPY when you drag to the new window/icon Quote Link to comment Share on other sites More sharing options...
robcatron Posted February 3, 2004 Author Share Posted February 3, 2004 1. Open your new destination folder/window and minimize it and drag it down to the lower right corner of the screen.2. Open up the folder/window that you want to copy the files out of and put it in the upper left corner of the screen. 3. Place the mouse pointer slightly above and to the left of the files you want to copy. 4. Click and hold the left mouse button and drag it over the files you want to copy, in order to highlight them. 5. Drag the highlighted files over to the new folder. When copying games that have multiple disks and some of the same file names on each disk, it will ask you if you want to overwrite the file, just select "Skip" and it will go to the next file to copy. Is this what you want to do? Well, sort of -- I am aware how to do that, but what if there are many files and folders, and you want to select them all or certain ones (that are not visible in the source folder)? The quickest way would be to select all, then deselect the ones that you didnt' want, but I can't get it to do that. thanks for you help! Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted March 21, 2023 Share Posted March 21, 2023 Can you copy all files and have it just over write duplicate file names without having to approve each one is a common question Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted March 22, 2023 Share Posted March 22, 2023 @_The Doctor__ that's a 19 year bump 3 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted March 22, 2023 Share Posted March 22, 2023 <E> (for everything) is only on the newer versions of TOS. I use it with TOS v2.06 and 3.06 here. TOS v1.4 here does not have that. As mentioned, <control> is for moving files. <Shift> will select a file and you can "lasso" and "rubber band" multiple files. Using <shift> again will deselect it. Just a thought, it might be a little less cumbersome with lower TOS versions to switch to an all text mode instead of icons, for these file operations. Otherwise, use an replacement desktop that allows a hot-key to select all files or upgrade your TOS version. Not sure but would any of the replacement file selectors allow mass selection and file operations? Can't remember... HTH's. Quote Link to comment Share on other sites More sharing options...
Zogging Hell Posted March 22, 2023 Share Posted March 22, 2023 Just find a copy of Kobold and use that for copying if you want to move large amounts of files. It is faster and has lots of home comforts including rename or overwrite. It is on here if you want to try it.. https://milan.kovac.cc/atari/software/?folder=/DISKTOOL Scroll down to the 2.5 version if you are English speaking, there is a 3 available but it is in German. Quote Link to comment Share on other sites More sharing options...
+Sauron Posted March 22, 2023 Share Posted March 22, 2023 Am I the only one who cringes when I read something I wrote almost 20 years ago? Ugh. Anyway, the advice above is recommended. When it came to copying or moving files in TOS, it was always better to use a third party utility, as native TOS file transfers are notoriously slow, especially on older versions. 2 1 Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted March 23, 2023 Share Posted March 23, 2023 On 3/22/2023 at 12:34 PM, Zogging Hell said: Just find a copy of Kobold and use that for copying if you want to move large amounts of files. It is faster and has lots of home comforts including rename or overwrite. It is on here if you want to try it.. https://milan.kovac.cc/atari/software/?folder=/DISKTOOL Scroll down to the 2.5 version if you are English speaking, there is a 3 available but it is in German. <snaps fingers!> This - another great option. I should have mentioned it as I have it installed on every TOS machine I have, although I tend to use it for larger file operations and use the standard desktop for the smaller ones. I also use it to erase those pesky files that Windows machines tend to scatter all over my SD cards when I do file transfers between the 2 platforms. 2 Quote Link to comment Share on other sites More sharing options...
geodom Posted July 12, 2023 Share Posted July 12, 2023 Shift + select files works fine on STE (1.06) Quote Link to comment Share on other sites More sharing options...
BJolly Posted July 12, 2023 Share Posted July 12, 2023 On 3/22/2023 at 3:24 PM, DarkLord said: <E> (for everything) is only on the newer versions of TOS. I use it with TOS v2.06 and 3.06 here. TOS v1.4 here does not have that. As mentioned, <control> is for moving files. <Shift> will select a file and you can "lasso" and "rubber band" multiple files. Using <shift> again will deselect it. Just a thought, it might be a little less cumbersome with lower TOS versions to switch to an all text mode instead of icons, for these file operations. Otherwise, use an replacement desktop that allows a hot-key to select all files or upgrade your TOS version. Not sure but would any of the replacement file selectors allow mass selection and file operations? Can't remember... HTH's. Yup Universal Item Selector - UISIII - completely replaces the system file selector within all GEM programs. It allows mass selection of files & their manipulation - as well as much more! Very handy especially on single tasking systems & works well with Hotwire 3. Quote Link to comment Share on other sites More sharing options...
BJolly Posted July 12, 2023 Share Posted July 12, 2023 (edited) Correction: UISIII replaces the system file selector even from the desktop. However there may be some Gem or semi gemmed programs that use their own custom file selector rather than the system file selector. Superbase Professional comes to mind as one of them. Edited July 12, 2023 by BJolly Quote Link to comment Share on other sites More sharing options...
