JohnA Posted February 29, 2004 Share Posted February 29, 2004 Hi all, I recently got a broken 2600 "Darth Vader" console and diagnosed a faulty PAL TIA chip. I scrounged one from my working 6-switch Woody and the fault on the Vader was cured I then ordered a replacement PAL TIA from Brad at Best Electronics (Thanks Brad!) which has arrived. I plugged the new TIA into my Woody and... Nothing I swapped the TIA/RIOT/CPU between the Woody and the Vader, and the Vader still works (so the three chips are all OK) but the Woody is still dead. Symptoms: Screen is black. It looks like a real TV signal because there is no interference, but there isn't any game either. When I switch the console off I get the usual snowy screen, so it definately looks like it's almost alive. I've checked the voltage regulator and it seems to be working fine. I have obviously upset something. Anyone got any suggestions what it might be ? Thanks in advance, JohnA. Quote Link to comment Share on other sites More sharing options...
Max-T Posted February 29, 2004 Share Posted February 29, 2004 Are you sure that the cartridge slot is still in proper alignment? I am definitely no Atari expert, but I have had a system before in which the system's PCB was slightly out of alignment. I got a red-and-black screen, as opposed to yur all-black screen, but I was just wondering. Best of luck! Max Quote Link to comment Share on other sites More sharing options...
JohnA Posted February 29, 2004 Author Share Posted February 29, 2004 Hi Max, Thanks for the suggestion - sadly the board isn't even back in the case yet. It's still on my work bench so I can't see how to get an alignment problem I think the slot is OK (could be wrong of course!) Regards, JohnA Quote Link to comment Share on other sites More sharing options...
