+Atarius Maximus Posted March 19, 2004 Share Posted March 19, 2004 I disassembled Thomas J's automatic shifting hack of Dragster, as I was curious about the change, and wanted to see if I could incorporate it into my DragRace hack. Well, I found his change and it works, although it seems to cause a few graphic glitches in the game. I asked Thomas before posting this, he gave me his permission, and kind of "challenged" me to see if I could fix the graphic glitch. Hmmm....We'll see. I know this change makes the game too easy, but it's interesting none the less. To change the normal Dragster bin into the automatic shifting version, make the following change: Change This: LF3E9: CMP #$20 ;2 BCC LF3FF ;2 LDA #$0F ;2 STA $D0,X ;4 LDA #$01 ;2 STA $D4,X ;4 LDA #$04 ;2 STA $AB,X ;4 LDA #$1A ;2 STA $CE,X ;4 LDA #$00 ;2 LF3FF: STA $A8,X ;4 To This: LF3E9: CMP #$20 ;2 BCC LF3FF ;2 LDA #$1F ;2 LDY $8D ;3 BNE LF3FB ;2 LDY $CC,X ;4 CPY #$04 ;2 BCS LF3FB ;2 INC $CC,X ;6 LF3FB: LDY $CC,X ;4 NOP ;2 NOP ;2 My updated version of DragRace is attached below. Here is the link to my original DragRace Hack thread: http://www.atariage.com/forums/viewtopic.php?t=24190 drauto.zip Quote Link to comment Share on other sites More sharing options...
Saikyo Posted March 19, 2004 Share Posted March 19, 2004 could make the game more interesting MIGHT try this one! Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 19, 2004 Share Posted March 19, 2004 The original code has 34 cycles being used between those 2 tags. Have you tried moving those 2 NOP instructions a little further north? Also, the Y register is being used in the replacement. Is that OK to use? Is it being thrown out after this code executes? Or is an instruction expecting a value there? You might need to save it (going into the code) and restore it later. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 PostPosted: Thu Mar 18, 2004 7:47 pm Post subject: The original code has 34 cycles being used between those 2 tags. Have you tried moving those 2 NOP instructions a little further north? icon_wink.gif Also, the Y register is being used in the replacement. Is that OK to use? Is it being thrown out after this code executes? Or is an instruction expecting a value there? You might need to save it (going into the code) and restore it later. Thanks for the suggestions, Nukey. I'm going to try and take a look at this later tonight, right now I've got two screaming kids pulling me in two different directions.... Ugh. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Ahhhh.. The kids are in bed, I've got some time to myself. I moved the NOP instructions "further north" as you suggested, but their placement didn't seem to make any difference. I suspect it is related to what you mentioned after that, the Y register is probably going to have to be read first then restored. Well, I'm not 100% sure how to go about that, so I guess it's time to get started on the fun part, some trial and error coding. How significant is it that the replacment code uses 33 cycles, whereas the original code uses 34? Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted March 19, 2004 Share Posted March 19, 2004 LOL AM....I thought you were sitting on a porch somewhere with NEO drinking a bartles and james discussing the latest hacks you both just came up with! Cheers Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 thought you were sitting on a porch somewhere with NEO drinking a bartles and james discussing the latest hacks you both just came up with! Um, Yeah! That's exactly what we do! Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 19, 2004 Share Posted March 19, 2004 If the program is expecting a specific amount of time to be happening at that point, even 1 cycle will throw things off. Why is Y loaded at the end? Is anything done with that? Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 If the program is expecting a specific amount of time to be happening at that point, even 1 cycle will throw things off. I figured that was the case, and that could be the root cause of the problem. Why is Y loaded at the end? Is anything done with that? I'm not exactly sure. I'm probably going to reveal my ignorance if I start talking about what I think is going on in the code. Here's what I've written down so far, still working on figuring out exactly what's going on, though: LF3E9: CMP #$20 ;2 Compare Accumulator BCC LF3FF ;2 Branch if A is less than or equal to #$20 LDA #$1F ;2 Load A Register LDY $8D ;3 Load Y Register BNE LF3FB ;2 Branch to LF3FB if Y is Not Zero LDY $CC,X ;4 Load Y (Zero Page) CPY #$04 ;2 Compare Y Register BCS LF3FB ;2 Branch on Carry Set. If it's a set, the branch is taken. If it's clear, then Increment Memory INC $CC,X ;6 Increment Memory by 1(?) LF3FB: LDY $CC,X ;4 Load Y (Zero Page) NOP ;2 No Operation (Waste 2 Cycles) NOP ;2 No Operation (Waste 2 Cycles) Here's where my "guessing" comes in, so don't be too hard on me. I think that A and Y are being compared because they represent the current revs and the max engine rev. If they aren't equal, Memory is incremented by 1 until they do. When they are equal, the BCS takes you to LF3FB, where Y is loaded again. Why? I don't know. I'm still working on it. AM EDIT: Corrections made to Code comments (Thanks, Nukey Shay). Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 19, 2004 Share Posted March 19, 2004 Correction: BNE LF3FB ;2 Branch to LF3FB if A and Y are not equal should be described as... BNE LF3FB ;2 Branch to LF3FB if Y is NOT zero The A register has nothing to do with it...since it's not being compared to Y in any way. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Thanks for the clarification. I told you I'd reveal my ignorance. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 19, 2004 Share Posted March 19, 2004 Another one: CMP #$20 ;2 Compare Accumulator BCC LF3FF ;2 Branch on Carry Clear...if the result of the comparison is less than the accumulator(?) ... CMP #$20 ;2 Compare Accumulator to $20 (decimal 32) BCC LF3FF ;2 Branch if A is less than or equal to #$20 Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Thanks again. If I can figure out exactly what each of these lines of code are actually doing, that will help immensely. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 19, 2004 Share Posted March 19, 2004 No prob. Keep in mind that people often use branching instructions as a replacement for JMP (which takes 3 bytes and uses 3 cycles). An example like... AND #$7F JMP Nextline ...could be trimmed to... AND #$7F BPL Nextline Nothing to do with your code example above, but useful to keep in mind so that you'll recognise when the program will ALWAYS branch. In this example, the upper bit is trimmed off by the AND instruction (that bit is used to determine if a value is positive or negative). Since the bit is now gone, we can just branch if plus...as long as it's a short distance. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 No prob. Keep in mind that people often use branching instructions as a replacement for JMP (which takes 3 bytes and uses 3 cycles). An example like... AND #$7F JMP Nextline ...could be trimmed to... AND #$7F BPL Nextline Wow, very cool, useful info. It makes so much more sense when it's explained like you did, rather than just reading a technical document that explains instructions & syntax. Regarding the code sample itself, what I'm struggling with the most is knowing exactly what the A and Y Registers represent. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 19, 2004 Share Posted March 19, 2004 Impossible to determine from such a small snippet. A is loaded with #$1F (the lower 5 bits turned on)...but then does nothing with that value. Y is also loaded with a new value at the end. Something must be happening with A and Y below that area I'd imagine. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Impossible to determine from such a small snippet. Yeah, I figured that. I'll have to dive a little deeper into the code to really figure this out, which is what I expected. A is loaded with #$1F (the lower 5 bits turned on)...but then does nothing with that value. Y is also loaded with a new value at the end. Something must be happening with A and Y below that area I'd imagine. Thank you for your comments and your help, I know you're plenty busy with other things. Now it's time to get to work on that new SI Deluxe Explosion sound! Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted March 19, 2004 Share Posted March 19, 2004 I really would like to help, but I absolutely can't remember what I did then. And it would take away a lot of fun, wouldn't it? Anyway, I would suggest looking the fire button code (something with INPT4/5). There the gears are shifted and probably you can recognize some variables there. Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Thanks for the tip, Thomas. Right now I'm making notes on the code using some 6502 documentation I downloaded. I'm just trying to figure out what everything does, which is pretty difficult for me. It's fun trying to figure it all out though, you're right! Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Hey, I finally broke 6 seconds on Dragster! | Quote Link to comment Share on other sites More sharing options...
neotokeo2001 Posted March 19, 2004 Share Posted March 19, 2004 Yeah, In a few more years I will look exactly like the guy on the right. Quote Link to comment Share on other sites More sharing options...
Christophero Sly Posted March 19, 2004 Share Posted March 19, 2004 Hey, I finally broke 6 seconds on Dragster! | Seriously...is that a screenshot from a run using the auto-shift hack? What exactly does the hack do...automatically shift gears when the RPMs reach maximum? What happens in 4th gear when RPMs reach maximum? Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Seriously...is that a screenshot from a run using the auto-shift hack? Yes, that score is from the hacked version. My best time with Dragster using unmodified code is 6.07. What exactly does the hack do...automatically shift gears when the RPMs reach maximum? What happens in 4th gear when RPMs reach maximum? Well, you could download it and try! Yes, the car automatically shifts when the revs reach maximum. In 4th gear, it revs up to the limit and stay there. You can never blow your engine. To play the game, all you're really doing is holding down the button for the entire race. Not a whole lot of fun, really. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted March 19, 2004 Share Posted March 19, 2004 Not a whole lot of fun, really. Try using the clutch! Quote Link to comment Share on other sites More sharing options...
+Atarius Maximus Posted March 19, 2004 Author Share Posted March 19, 2004 Try using the clutch! I hadn't really thought of that. Quote Link to comment Share on other sites More sharing options...
