noteit Posted March 31, 2004 Share Posted March 31, 2004 The attached file is an ATR type file. You will need an emulator that can play such files on your atari or ibm, or other computer. I use the Ape emulator, and play the files on an atari 800 The game maker, Mazeit should be run with atari basic cartridge. You should have a disk that has been formated, and dos, and dup sys installed on it. And a copy of rollem.obj, and rollem.maz The program will fill up the disk with rollem games that have 60 screens each. It takes an hour or so to fill up a floppy with games. When the programs stops, and you might get an error message, you then go to dos, and first copy what screen you want to play to rollem.maz Then you load rollem.obj You might get some screens in a game that can not be completed to advance to the next level. On these screens, you will need to die 3 times, and then pull down on the joy stick to skip to the next sceeen, or any screen you wish. This disk you download, has many games on it already made for you. Ape users only read this: Ape emulator users, can run the game maker, mazeit. They just need to load the atr into a drive, and then when asked the file name, use the same drive. It does not seem to be able to work on one ape drive, and make a maze on another ape dirve. rollemi.zip Quote Link to comment Share on other sites More sharing options...
