Tezz Posted May 15, 2004 Share Posted May 15, 2004 Hi all, er.. I need a bit of a memory jog. I am about to image my Atari disks so I can back them up onto CD and also access them under emulation and of course post anything unique here on the forum. I use the Catweasel controller on the Amiga but, it''s been a while since I used it and I've lost my multidisk.device listing As I have just read up on the net, the 1050 drive could write the following: 1) Single-Sided, Single-Density, 90K which was 810 compatible 2) Single-Sided, Dual-Density, otherwise known as "Enhanced Density" because it is not true double-density MFM 40 tracks x 26 sectors/track x 128 bytes/sector = 128K capacity I need a little help with the nessasary fields on the Amigas DOS mount device can anyone tell me what is the correct BlockSize should I use? and how many BlocksPerTrack? Is a disk one surface when it's double density? Here's the listing below........ /* multidisk file system entry * * This mounts a logical device on catweasel unit 0 for reading 180K Disks */ FileSystem = L:CrossDOSFileSystem Device = multidisk.device Unit = 0 Flags = 24 /* makes an Atari 800 XL 180 Kbytes single-sided driver */ BlockSize = 512 Surfaces = 1 BlocksPerTrack = 9 Reserved = 1 Interleave = 0 LowCyl = 0 HighCyl = 39 Buffers = 5 BufMemType = 1 StackSize = 2048 Priority = 5 GlobVec = -1 DosType = 0x4D534400 Activate = 1 As always, any help appreciated... Thanx Tezz Quote Link to comment Share on other sites More sharing options...
miker Posted May 16, 2004 Share Posted May 16, 2004 hmmm... Shouldn't be: BlockSize = 256 The 512B sectors are available in "IBMSD" density in some modified disk drives... But i may be wrong anyway... Quote Link to comment Share on other sites More sharing options...
miker Posted May 16, 2004 Share Posted May 16, 2004 and... maybe BlockSPerTrack = 18 /who the heck disabled editing posts here, wrrrrrr!/ Quote Link to comment Share on other sites More sharing options...
voy Posted May 17, 2004 Share Posted May 17, 2004 Did you try to use 551conv program? Few years ago I was using this cool prog to read Atari disks directly from the Amiga 5.25" drive and it was working ... As I remember, I hooked up an original Amiga 3.5" drive to XF551's Shuggart connector... An Atari XL/XE with 3.5" disks - it was amazing! I was suprised when I discovered that 551conv can read such prepared disks ... Here is the link to 551conv: http://www.aminet.net/~aminet/misc/emu/551conv.lha and to its GUI: http://www.aminet.net/~aminet/misc/emu/551convGUI.lha Now I use PC-TASK 4.40 emulator with APE 1.17 and SIO2PC cable with CTS line active. This is the best solution for Amiga-Atari fan like me ... Quote Link to comment Share on other sites More sharing options...
Tezz Posted May 18, 2004 Author Share Posted May 18, 2004 Thanks for that everyone, I will try to put the device driver together later this week. voy Did you try to use 551conv program? Few years ago I was using this cool prog to read Atari disks directly from the Amiga 5.25" drive and it was working ... As I remember, I hooked up an original Amiga 3.5" drive to XF551's Shuggart connector... An Atari XL/XE with 3.5" disks - it was amazing! Yes, thanks voy. I have used 551 conv before and I have recently downloaded the latest from Aminet. My current Amiga set-up has a PC 5.25" drive connected to the Catweasel controller but, I do have an old Amiga 5.25" drive which I think is Amiga 500 only compatible. I guess failing setting up a new driver I could set-up my Amiga 500 and image the disks to an Amiga floppy and then copy the images to my Amiga tower for burning to CD/DVD. Must archive these old 5.25" floppies !! I doubt that Verbatims lifetime guarranty will ensure that they will read for ever!! Quote Link to comment Share on other sites More sharing options...
