Heaven/TQA Posted May 20, 2004 Share Posted May 20, 2004 what is the default value of $d301? thanks... Quote Link to comment Share on other sites More sharing options...
analmux Posted May 20, 2004 Share Posted May 20, 2004 ...that depends on which system you're using. $d300 and $d301 are general bidirectional multipurpose ports $d301 is joystick 3&4 on the atari 400/800 line, so has no default value (as it is read only) $d301 on the 600xl/800xl/65xe etc. line is write only and has value $fd =253 bit 0 on means OS-ROM enabled bit 1 off means Basic-ROM enabled so $fe (254) will turn ALL ROM off. And when you do so, be sure to disable all kinds of interrupts (IRQ/NMI) and then replace the vectors at $fffa,$fffe Quote Link to comment Share on other sites More sharing options...
analmux Posted May 20, 2004 Share Posted May 20, 2004 Oh yes...bit 7 on means selftest ROM at $5000-$57ff disabled. funny, I tried once if the 2kb invisble RAM from $d000-$d7ff would apear on the selftest area ($5000-$57ff) when selftest ROM (part of OS-ROM mapped 32 kb back in memory) enabled but OS-ROM turned off: bit 7=0, bit 0=0: $7e or 126 No effects.... Quote Link to comment Share on other sites More sharing options...
analmux Posted May 20, 2004 Share Posted May 20, 2004 ....and with control registers $d302, $d303 (bit 2 turned off/on?) you can reach the data-direction registers: now $d300 and $d301 are used for setting the R/W direction on the same registers. Quote Link to comment Share on other sites More sharing options...
