dinovelvet Posted May 28, 2004 Share Posted May 28, 2004 I recently got a 2600 6 switch console that plays fine, except that I can't get any joystick to fire on it. They all move perfectly in every direction, and I know its not the fault of the joysticks as they all operate on other consoles, so its this one particular 2600 that isn't responding to the fire button. I looked at the joystick input and the 9 pins are in place. Any ideas what the problem could be and how to fix it? Thanks. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted May 28, 2004 Share Posted May 28, 2004 I just fixed a machine that didn't work in the up direction, ended up being the joystick port pin on the back of the port was cracked in half. Can't see that from the outside. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted May 28, 2004 Share Posted May 28, 2004 Indeed. If you're at all any good with a soldering iron, open the machine up, remove the RF sheilding and take a look at the underside of the board where the joystick ports are soldered. Chances are you'll probably see that one or more of the pins have worked loose of the solder. That happens a lot over time with soldered components that take a lot of abuse (such as plugging and unplugging of peripherals). You'll need to reflow the solder points (melt them so the solder reforms around the pins). A little tedious but works a charm. I've done this on a number of consoles that had various problems. (Finky AC plugs, RF plugs, joystick ports, etc.) Quote Link to comment Share on other sites More sharing options...
ATARIPITBULL Posted May 28, 2004 Share Posted May 28, 2004 Hey dino, I did not know you were a member here, I have bought a few things off of you from Ebay, Nice to have you aboard!! Quote Link to comment Share on other sites More sharing options...
dinovelvet Posted May 29, 2004 Author Share Posted May 29, 2004 Indeed. If you're at all any good with a soldering iron Ah...that's a big IF, in my case I'll just have to add it to my "semi-working" pile that I'll throw on ebay at some point. Thanks for the tips anyway! Quote Link to comment Share on other sites More sharing options...
