Trev Posted June 9, 2004 Share Posted June 9, 2004 When using the paddle controllers, Indy 500 works fine, but Night Driver and Breakout won't work at all. The picture looks fine, and the reset/select buttons work. Paddles are dead on those games only. Any ideas? Rock on Quote Link to comment Share on other sites More sharing options...
elviticus Posted June 9, 2004 Share Posted June 9, 2004 Are you sure you're not using driving controllers? Indy 500 uses these, and the other 2 use paddles. Quote Link to comment Share on other sites More sharing options...
Trev Posted June 9, 2004 Author Share Posted June 9, 2004 Ah!! What about that?!? I think you may be right.....Thanks for the help! Rock on Quote Link to comment Share on other sites More sharing options...
Big Player Posted June 9, 2004 Share Posted June 9, 2004 The paddle controllers are wired so that two controllers fit in one joystick port. The dials can only be spun so far to the left and right with paddles. The driving controllers are like joysticks, one port per controller. You can spin the dials on driving controllers in either direction indefinitely. Hope that helps. Quote Link to comment Share on other sites More sharing options...
