digitalwndr Posted June 10, 2004 Share Posted June 10, 2004 What's the best way to tight it up... it's loose so whenever I turn it on I need to wiggle to show the game. Any ideas? Quote Link to comment Share on other sites More sharing options...
InanimateCarbonRod Posted June 10, 2004 Share Posted June 10, 2004 If you can solder / de-solder, just switch it with the BW / Color Switch. Most likely the BW / Color switch has never been used anyway and is good as new. Another option is to take apart the Power switch and 'tighten' up the contacts - in my experience, this works "OK", but I prefer to switch the power switch with the BW / Color one - I've done it on a couple of units to date. Jerry Quote Link to comment Share on other sites More sharing options...
digitalwndr Posted June 10, 2004 Author Share Posted June 10, 2004 using the existing solder on the board? pretty painless for a newbie to soldering?... (I've soldered once before) Quote Link to comment Share on other sites More sharing options...
InanimateCarbonRod Posted June 10, 2004 Share Posted June 10, 2004 Definitely NOT a soldering job for the inexperienced. You should avoid this method if you're not good or experienced with soldering. In my personal experience, I also don't like taking the switch apart and adjusting it, but it DOES help with the function of the switch - but you have to be really careful. Your best bet may be to 'bypass' that switch altogether. Do you have any other spare switch lying around? Something mountable to the ATARI body would work great. I've installed another switch to the ATARI body and then wired it up to where the current switch is wired - in essence bypassing the original switch altogether. This works, but takes away from the original look of the system - depends how picky you are, I guess... Hope this helps, Jerry Quote Link to comment Share on other sites More sharing options...
povlok1 Posted June 10, 2004 Share Posted June 10, 2004 try cleaning it first, even loose switches will work fine if they are clean (in most cases) get some contact cleaner at radio shack Quote Link to comment Share on other sites More sharing options...
digitalwndr Posted June 10, 2004 Author Share Posted June 10, 2004 maybe I'll do some practice runs on some old gear and then try... Thanks for all the help! Quote Link to comment Share on other sites More sharing options...
Tsukasa Posted June 10, 2004 Share Posted June 10, 2004 What ya do is get a nice, good, heavy-duty toggle switch and mount it into the switch panel. Or, better yet, replace it with a push button switch like the one on the nes. Quote Link to comment Share on other sites More sharing options...
povlok1 Posted June 10, 2004 Share Posted June 10, 2004 What ya do is get a nice' date=' good, heavy-duty toggle switch and mount it into the switch panel. Or, better yet, replace it with a push button switch like the one on the nes. [/quote']yuck.. if anything.. ask and Ill send you a good, near new switch to replace;) Quote Link to comment Share on other sites More sharing options...
Tsukasa Posted June 10, 2004 Share Posted June 10, 2004 What, there's nothing wrong with the switch panel on your 2600 reminding you of a blender. If you get an on-off-momentary on switch, you could wire pulse to reset. Quote Link to comment Share on other sites More sharing options...
digitalwndr Posted June 10, 2004 Author Share Posted June 10, 2004 I just don't know that my soldering skills would allow to replace that switch without killing it :-( How about it? Can a new solderer solder a new switch on? Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted June 10, 2004 Share Posted June 10, 2004 If you are no good at soldering but are good at working with small parts you could always take the switch apart. It is pretty easy to get it apart, but getting it back together can be tricky sometimes. Bend the 8 tabs on the side of the switch in take the top of the swithc off, clean and bend the contacts so they hit harder and then put it back together. I have done it to my system one time and it has worked like new ever since. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted June 10, 2004 Share Posted June 10, 2004 If you are no good at soldering but are good at working with small parts you could always take the switch apart. It is pretty easy to get it apart' date=' but getting it back together can be tricky sometimes. Bend the 8 tabs on the side of the switch in take the top of the swithc off, clean and bend the contacts so they hit harder and then put it back together. I have done it to my system one time and it has worked like new ever since. [/quote'] Sounds a lot like disassembling the pot in a set of paddles -- pretty simple as long as you pay attention to the order things got taken apart. :-) Quote Link to comment Share on other sites More sharing options...
bjk7382 Posted June 10, 2004 Share Posted June 10, 2004 Sounds a lot like disassembling the pot in a set of paddles -- pretty simple as long as you pay attention to the order things got taken apart. :-) Yeah it isn't very hard to do the power and black and white switches, but it is tough to get the reset and select switches back together with the spring going back in right. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted June 10, 2004 Share Posted June 10, 2004 Sounds a lot like disassembling the pot in a set of paddles -- pretty simple as long as you pay attention to the order things got taken apart. :-) Yeah it isn't very hard to do the power and black and white switches' date=' but it is tough to get the reset and select switches back together with the spring going back in right.[/quote'] If worse came to worst would you be able to replace those with a generic two-prong momentary switch? I have plenty of access to those and generic toggle switches (the sort used in the difficulty switch on four-switchers) at cost, so it'd be cool to know I could get some cheaply. :-) Quote Link to comment Share on other sites More sharing options...
