Rick Weis Posted July 13, 2004 Share Posted July 13, 2004 Hello, i just hooked up my atari 800XL and a floppy drive (1050). question! do i need to type in something to get the computer to read the floppy? i have gotten a few (not many) floppies to work, but some won't do anything, it will just show ready on the tv. could this be a drive problem? or a floppy problem (old floppy) all but 1 floppy is very old and the new one just keeps making the screen turn on and off. also my drive is very old (USED) (it's been a looooong time since i used a floppy drive) Please Help this dummy! Thanks, Rick Quote Link to comment Share on other sites More sharing options...
classics Posted July 13, 2004 Share Posted July 13, 2004 Hold down OPTION while turning on the computer to disable BASIC. Most disk games require BASIC to be disabled in order to run. Steve Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted July 13, 2004 Share Posted July 13, 2004 Deep within the Atari computer's operating system (the machine-language program that runs in the background that reads the keyboard, etc), there is a very crude I/O subroutine. This subroutine is run when you first turn on the computer. What it does is check to see what devices are present (connected and turned on). If a disk drive is detected, the computer resets the drive to the lowest sector of the disk and attempts to read the data there and execute it. This is called "booting" the disk. Note: if no disk is inserted or no "boot" program is present on the lowest sector, the screen will print the message "boot error" infinitely. What the boot program does on most user disks is load in a more complex I/O program to deal with disks. This is commonly referred to as "DOS" (Disk Operating System). This program attempts to integrate itself to the regular operating system...which will allow you to use specific commands to access the drive and files. In actuality, a DOS "master" disk is divided into 2 programs besides the boot loader (DOS.SYS and DUP.SYS)...plus 2 optional files (AUTORUN.SYS and MEM.SAV). DOS.SYS is the name of the larger I/O program that allows you, the human, to use commands to manually access the drive. Because these commands are still relatively complex, a second program was created... DUP.SYS (or Disk Utility Package)...this second half is a "menu" program that allows you to use the commands in as few as just a couple of keypresses. When called, it will overwrite any user program in memory and display the menu on-screen. It can be called by booting the master disk when no cartridge is present...or by typing the instruction DOS in Basic. Because the program in memory will be wiped out by DUP.SYS when it's used, the user can activate an option called MEM.SAV. This file will contain the Basic program currently in memory before DUP.SYS overwrites it. Then when the DUP.SYS menu program is exited, MEM.SAV is loaded back in memory...leaving the Basic program intact. AUTORUN.SYS is the reserved name for any program that the user wants to automatically load and execute when that disk is booted. It must be a machine-language program only. Therefore, any user disk that you wish to boot must at the very least contain a copy of the DOS.SYS file (in addition to the boot loader). Commercial programs generally do not use any of that...but the entire game program IS the boot file. So usually all that is required is to turn on the disk drive, insert the disk, and then turn on the computer. Because commercial programs are usually written in machine-language, you'll need to hold down the -option- key to disable the built-in Basic that is in your XL computer when you turn it on. If this is not done, there is a very good chance that the program will not load/execute at all. Quote Link to comment Share on other sites More sharing options...
Rick Weis Posted July 13, 2004 Author Share Posted July 13, 2004 Thanks guys! i will try that today! Rick Quote Link to comment Share on other sites More sharing options...
deathtrappomegranate Posted July 13, 2004 Share Posted July 13, 2004 Quote Link to comment Share on other sites More sharing options...
Rick Weis Posted July 17, 2004 Author Share Posted July 17, 2004 <rushes to buy 8-bit carts before it's too late> hehe.. don't worry! i not buying any new ones. :wink: Rick Quote Link to comment Share on other sites More sharing options...
Brad2600 Posted July 19, 2004 Share Posted July 19, 2004 I am hoping to find a disk drive for my 800XL as well. I only use carts right now. Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted July 19, 2004 Share Posted July 19, 2004 Google for "sio2pc cable". Why not turn your PC into a big Atari disk drive? Quote Link to comment Share on other sites More sharing options...
