Tezz Posted August 6, 2004 Share Posted August 6, 2004 Hi all, I have a few small coding questions: I am of course these days using Fox's great XASM which makes coding via the PC a nice experience although, I'm not totally familiar yet with the Quick Assembler as I used to use the very old Atari Assembler back then as I never got a MAC65 cartridge. There are a few differences with the syntax which I am now familiarising myself with. As well as trying to remember all of the 6502 that I once knew! After looking through some XASM sourcecode, I was wondering about this command: ror @ <---- I assume that this is (as the documentation states) marked with the @ as it is the accumulator addressing mode? Can someone clarify exactly what this is doing? Here is an example of a section of code SETPOS LDA $84 SEC SBC $B7 STA $84 AND #$03 STA $86 LDA $84 AND #$FC CLC ror @ ror @ ADC $82 STA $8A LDA $83 ADC #$00 STA $8B LDA $85 AND #$07 STA $87 LDA $85 AND #$F8 CLC ror @ ror @ ror @ TAX CPX #$00 BEQ SETPOS2 SETPOS1 CLC LDA $8A ADC #$30 STA $8A LDA $8B ADC #$00 STA $8B DEX BNE SETPOS1 also, another very basic question.. in my old source code I could deifine bytes by.. LABEL .byte $70,$70,$70 etc. I have tried to replace this with.. LABEL dta b $70,$70,$70 etc. XASM compains that a label hasn't been defined on the line that contains the first dta b should I just use dta $70,$70,$70 As always, Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted August 6, 2004 Share Posted August 6, 2004 Yes, it looks like 'ror @' means 'ror a' or simply 'ror'. BTW: CLC ror @ ror @ ror @ That's a perfect example of the programmer not knowing exactly what the opcode does and which opcodes are available too. Instead he could have written: lsr @ ror @ ror @ I have seen this mistake quite often in old code, probably the 650x documentation wasn't very complete. Quote Link to comment Share on other sites More sharing options...
Tezz Posted August 6, 2004 Author Share Posted August 6, 2004 Thanks Thomas, I thought it was just me! Quote Link to comment Share on other sites More sharing options...
dely Posted August 6, 2004 Share Posted August 6, 2004 LABEL.byte $70,$70,$70 etc. Quick Asm: label dta b($70),b($70),b($70) XASM: label dta b($70,$70,$70) Quote Link to comment Share on other sites More sharing options...
Tezz Posted August 6, 2004 Author Share Posted August 6, 2004 dly XASM: Code: label dta b($70,$70,$70) Thanks for that. I thought it'd be something like that. Cheers :wink: Quote Link to comment Share on other sites More sharing options...
dely Posted August 6, 2004 Share Posted August 6, 2004 Cheers :wink: In Poland we used to say "Po szklanie i na rusztowanie" Quote Link to comment Share on other sites More sharing options...
Dracon Posted August 7, 2004 Share Posted August 7, 2004 :wink: Quote Link to comment Share on other sites More sharing options...
Tezz Posted August 7, 2004 Author Share Posted August 7, 2004 dely In Poland we used to say "Po szklanie i na rusztowanie" OK ! In my Polish to English translator, this comes out as... "For (after) glass and on rusztowanie" anyway.. Okrzyki ! for your help :wink: Quote Link to comment Share on other sites More sharing options...
Tezz Posted August 7, 2004 Author Share Posted August 7, 2004 Some more help if possible.. I'm just now using Code Genie front end for XASM and have set-up the config file as Fox describes in the documentation. For some reason it's not generating the object file? In the output window, I get "Running xasm.exe /p" and my path and source file is then listed correctly after this. I then get "Process terminated successfully." "Exit code 3" And no object file is created?? the xasm.exe executable is in the same directory as code genie Any ideas what I am doing wrong? Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted August 8, 2004 Share Posted August 8, 2004 do not know... but one problem i have discovered in the past was that code genie was configured in unix mode and not dos mode regarding CR/line end maybe this is causing the problem? have you checked a dummy XASM program like putting simple colours on screen etc? just to see if the assembling works correctly? will the object file being generated when using xasm manually? Quote Link to comment Share on other sites More sharing options...
Tezz Posted August 8, 2004 Author Share Posted August 8, 2004 Thanks Heaven, I worked it out. It seems that either XASM has a limit to the path length to compile from or that one of my folder names had a space in it (I never normally do this ). I copied my whole Code-Genie/XASM folder to the raw C drive path and it works fine now. Quote Link to comment Share on other sites More sharing options...
dely Posted August 8, 2004 Share Posted August 8, 2004 Any ideas what I am doing wrong? I have following setup: Code Genie is in: D:EmuAtariXEUtil-PC-CGCode Genie 3.0> Xasm is in: D:EmuAtariXEUtil-PC-CG> Also in above directory i have x-asm.bat. With following content: d:emuAtariXEUtil-PC-CGxasm.exe %1 /l /o:blah.xex In cgenie.conf i have following content: AddUserTool Xasm D:emuAtarixeutil-pc-cgx-asm.bat $FP CaptureOutput This works fine Quote Link to comment Share on other sites More sharing options...
