bloatedmonkey Posted August 12, 2004 Share Posted August 12, 2004 I received these a couple years ago along as part of a package of "Atari Service" replacement parts. All of the parts are for the 2600, so I assume the chips are also. I have a service manual, but the codes on these chips are not listed. So I was wondering if one of you tech guys could tell me what these are (if they are indeed for the 2600) in layman's terms. Thanks. IC GTIA - CO14805 (2") IC POKEY - CO12294 (2") IC ANTIC - CO12296 (2") IC 74LS10 - CO14339 (3/4") IC 74LS244 - CO14313 (3/4") Quote Link to comment Share on other sites More sharing options...
Mindfield Posted August 12, 2004 Share Posted August 12, 2004 GTIA, ANTIC and Pokey are all out of an 8-Bit Atari or 5200. GTIA and ANTIC take care of video, and POKEY is audio. I'd imagine the others are probably also from an 8-bit or 5200 if they came in the same kit. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted August 12, 2004 Share Posted August 12, 2004 Yeah, they're from a 5200/8-bit alright. Those last two chips are most likely RAM chips. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted August 12, 2004 Share Posted August 12, 2004 I'm thinking they're probably controllers. The DRAMs are probably generic off-the-shelf chips; a repair kit would usually contain items specific to the unit they're for that can't be sourced elsewhere. Quote Link to comment Share on other sites More sharing options...
Robert M Posted August 12, 2004 Share Posted August 12, 2004 IC 74LS10 - CO14339 (3/4") IC 74LS244 - CO14313 (3/4") These 2 are standard low-power TTL logic chips. 74LS10 is a Triple 3-input NAND gate chip: - There are 3 logic gates on this chip. Each gate has 3 inputs and 1 output. The output is low only when all 3 inputs are high. 74LS244 is an Octal 3-state Line Buffer/Driver chip: This chip has 8 gates with 1 input and 1 output each. The output equals the input. Every digital chip ouput has a fan-out rating. The fan-out is the number of inputs that can be connected to that output before the amout of power the inputs need exceeds what the output pin can provide. By using a buffer, you can effectively increase the fan-out of an output at the cost of some system speed. These are both standard logic chips that can be bought for less than $1 Cheers! Quote Link to comment Share on other sites More sharing options...
