alienblue Posted September 19, 2004 Share Posted September 19, 2004 Here's my problem (well, one of many...). I have three sets of paddles that dont work...well today I found a coleco Gemini Stick/paddle combo and lo and behold the paddle works great! One problem...the button works only on joystick games (I do not have the Gemini system...I'm using this on a 4 switcher and 7800)...HOWEVER it is possible to "activate" the button by jiggling the stick..so I can play BREAKOUT and CIRCUS (awkwardly) but not paddle games that require the button. Interestingly, Indy 500 works ok!!! No driving controller needed! Query...is it possible to rewire the button somehow If not, can "dead" paddles be revived (I'm not talking "jiggles" I mean, no movement on screen atall) thanks! Quote Link to comment Share on other sites More sharing options...
Mindfield Posted September 19, 2004 Share Posted September 19, 2004 The problem with combined Paddle/Joysticks is that unless you have a switch on the console to switch from paddle to joystick mode (ala Atari 2800/Sears Video Arcade II) then the lines will never get remapped to where they're supposed to be (ala Gemini). By default, the paddle trigger is mapped to joystick right, so on the Gemini you have to move the stick right to activate the paddle trigger. Conceptually, it would be possible to modify the controllers to insert a switch to which the joystick right and trigger buttons would be attached where the switch would swap the two when proper paddle mode is needed. Quote Link to comment Share on other sites More sharing options...
Breakpack Posted September 19, 2004 Share Posted September 19, 2004 The problem with combined Paddle/Joysticks is that unless you have a switch on the console to switch from paddle to joystick mode (ala Atari 2800/Sears Video Arcade II) then the lines will never get remapped to where they're supposed to be (ala Gemini). By default, the paddle trigger is mapped to joystick right, so on the Gemini you have to move the stick right to activate the paddle trigger. Conceptually, it would be possible to modify the controllers to insert a switch to which the joystick right and trigger buttons would be attached where the switch would swap the two when proper paddle mode is needed. And another thing with those controllers:You couldnt get a good 'ol fashioned four player game of Warlords goin' Quote Link to comment Share on other sites More sharing options...
Mindfield Posted September 19, 2004 Share Posted September 19, 2004 And another thing with those controllers:You couldnt get a good 'ol fashioned four player game of Warlords goin' Actually, you could, but you'd need to use a pair of joystick couplers and you'd have to modify two of the paddle/sticks to remap the paddle lines on players 2 and 4. More work than it's worth, frankly. :-) Quote Link to comment Share on other sites More sharing options...
Classic Pac Posted September 19, 2004 Share Posted September 19, 2004 What those 2 forgot about or simply don't know is that the Gemini came with a Y adaptor plug which activated the paddles. I should know I owned one, I still have 1 Gemini controller and the Y adaptor Quote Link to comment Share on other sites More sharing options...
Mike OC Posted September 19, 2004 Share Posted September 19, 2004 With a Gemini Paddle/Joystick combo, Up (on the Joystick) is "fire" in Paddle games. The fire button is only mapped to fire in Joystick games. Just fyi. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted September 19, 2004 Share Posted September 19, 2004 I haven't ever used one of these, but I always got the impression that having to jerk the paddle-stick in one direction to "fire" would be very lame. Too bad there wasn't a way to wire up a switch inside the controller that would change the function of the button and the stick if in "paddle" mode. Still... I guess it was kind of cool that they combined them into one controller at all. (Kind of.) Quote Link to comment Share on other sites More sharing options...
Mike OC Posted September 19, 2004 Share Posted September 19, 2004 I haven't ever used one of these, but I always got the impression that having to jerk the paddle-stick in one direction to "fire" would be very lame. Too bad there wasn't a way to wire up a switch inside the controller that would change the function of the button and the stick if in "paddle" mode. Still... I guess it was kind of cool that they combined them into one controller at all. (Kind of.) Actually it's pretty comfortable. I use the back of my thumb. The Paddle is below the stick and the controller case is long enough to be comfortably held with two hands and operate. It did take a few minutes for me to figure out though. I was testing Warlords, pressed fire, and nothing happened. After opening the controller and looking at the wiring I tried "Up" and found that it would fire. Quote Link to comment Share on other sites More sharing options...
snorlaxnut Posted September 20, 2004 Share Posted September 20, 2004 I have 2 Gemini controllers, but lost the "Y" connector. What I did was open one controller and looked at the wiring. From top to bottom it was: Yellow Brown Red Orange Gray Blue Green Purple I just pulled off the blue and yellow wires and switched them so it went: Blue Brown Red Orange Gray Yellow Green Purple Put the cover back on and now the fire button works when I just use the one Gemini controller to play paddle games. The only problems are that the joystick part does not work. And I don't know if the fixed controller works with all paddle games. The only paddle games I have are Super Breakout and Circus Atari. The one player games on those carts work fine with the fixed controller. Quote Link to comment Share on other sites More sharing options...
