spongebue Posted September 24, 2004 Share Posted September 24, 2004 I have itunes anyways, I'm just putting in a vote for everyone else and helping others download and donate. Anyways, I'm listening to Limitations of the System right now (the song, that is) and it is great. The higher pitched melody has a great carefree "floating" sound to it, which I love. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted September 24, 2004 Author Share Posted September 24, 2004 Thank Paul Slocum for that... it's the Synthcart! Quote Link to comment Share on other sites More sharing options...
frogstar_robot Posted September 25, 2004 Share Posted September 25, 2004 If you have the w32codec pack installed then you can use Mplayer to play those AACs. The only ones you'll run into trouble with are the ones with DRM on them. I was able to play them no problem. xxxxxxx@Amelia-Bedelia:~$ mplayer BoogiePreacher.m4a MPlayer 1.0pre5-3.3.4 © 2000-2004 MPlayer Team CPU: Intel Pentium 4/Xeon/Celeron Foster 2816 MHz (Family: 8, Stepping: 5) Detected cache-line size is 64 bytes MMX2 supported but disabled SSE supported but disabled SSE2 supported but disabled CPUflags: MMX: 1 MMX2: 0 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0 Compiled for x86 CPU with extensions: MMX Reading config file /etc/mplayer/mplayer.conf Reading config file /home/dmaxwell/.mplayer/config Reading /home/dmaxwell/.mplayer/codecs.conf: Can't open '/home/dmaxwell/.mplayer/codecs.conf': No such file or directory Reading /etc/mplayer/codecs.conf: 73 audio & 180 video codecs Using Linux hardware RTC timing (1024Hz). Can't open input config file /home/dmaxwell/.mplayer/input.conf: No such file or directory Input config file /etc/mplayer/input.conf parsed: 53 binds Opening joystick device /dev/input/js0 Setting up LIRC support... mplayer: could not connect to socket mplayer: No such file or directory Failed to open LIRC support. You will not be able to use your remote control. Playing BoogiePreacher.m4a. Cache fill: 0.00% (0 bytes) ISO: File Type Major Brand: Apple iTunes AAC-LC Audio QuickTime/MOV file format detected. -------------- MOV track #0: 416 chunks, 8723 samples Audio bits: 16 chans: 2 rate: 44100 MOV: Found MPEG4 audio Elementary Stream Descriptor atom (51)! Fourcc: mp4a -------------- MOV: longest streams: A: #0 (8723 samples) V: #-1 (0 samples) ========================================================================== Trying to force audio codec driver family libmad... Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding) FAAD: compressed input bitrate missing, assuming 128kbit/s! AUDIO: 44100 Hz, 2 ch, 16 bit (0x10), ratio: 16000->176400 (128.0 kbit) Selected audio codec: [faad] afm:faad (FAAD AAC (MPEG2/MPEG4 Audio) decoder) ========================================================================== Checking audio filter chain for 44100Hz/2ch/16bit -> 44100Hz/2ch/16bit... AF_pre: af format: 2 bps, 2 ch, 44100 hz, little endian signed int AF_pre: 44100Hz 2ch Signed 16-bit (Little-Endian) alsa-init: got device=0, subdevice=0 alsa-init: 1 soundcard found, using: default alsa: 44100 Hz/2 channels/4 bpf/65536 bytes buffer/Signed 16 bit Little Endian AO: [alsa] 44100Hz 2ch Signed 16-bit (Little-Endian) (2 bps) Building audio filter chain for 44100Hz/2ch/16bit -> 44100Hz/2ch/16bit... Video: no video Starting playback... Quote Link to comment Share on other sites More sharing options...
uosipa llamxew Posted September 25, 2004 Share Posted September 25, 2004 Worked on the first try here. I'm using WinXP... Winamp5, full install. I really like "Saturday Morning". Quote Link to comment Share on other sites More sharing options...
Bryan Posted September 25, 2004 Share Posted September 25, 2004 If MP3 offends your ears, encode to OGG instead. It's open-source, better quality than MP3 and AAC at equivalent bitrates, and is supported by all the major media players. Yeah, I don't understand why Vorbis is so ignored. It seems like the current trend is toward WMA. What is it about free and superior that turns people off? -Bry Quote Link to comment Share on other sites More sharing options...
herr professor Posted September 26, 2004 Share Posted September 26, 2004 QUOTE("Bryan" Yeah @ I don't understand why Vorbis is so ignored. It seems like the current trend is toward WMA. What is it about [b) free[/b] and superior that turns people off? -Bry not people... Record companies... when is the last open source mp3 hardware that has been released as a freeare shematic? Most of the hardware mp3 companies are arms of the same corperations that own the records companies, so of course they will push drm equipped hardware this is probaly why its taken sony so lon to come out with their ipod knockoff that and their love affair with atrac Quote Link to comment Share on other sites More sharing options...
Rockin' Kat Posted September 26, 2004 Share Posted September 26, 2004 Room 34: I think your stuff sounds really cool. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted September 27, 2004 Author Share Posted September 27, 2004 Room 34: I think your stuff sounds really cool. Thanks! BTW, sorry I've been incommunicado on this thread lately... I spent the whole weekend stripping wallpaper and repainting the kitchen. 16 hours on Saturday alone!!! Quote Link to comment Share on other sites More sharing options...
