crc_73 Posted October 19, 2004 Share Posted October 19, 2004 Does anyone else have problems with their game cards staying put with the older design carry case (the one without the velcro window flap to hold the cards in)? The cards invariably come out with the least amount of movement, and end up all over the shop. Anyone with any quick solutions? Quote Link to comment Share on other sites More sharing options...
kuifje76 Posted October 19, 2004 Share Posted October 19, 2004 got the same problem, I just putted it aside.... Quote Link to comment Share on other sites More sharing options...
EricDeLee Posted August 28, 2005 Share Posted August 28, 2005 I use items like this to hold my carts within the Lynx Carrying Case: Not this brand... but similar boxes. They are cheap. Hold well. Just rotate the carts so that they stack together without stacking with a 'slant' Not sure if that made any sense... but if you stacked Lynx carts in the past, I'm sure you know what I mean. I Currently have two 100 card count boxes holding most games. A 50 count box holding games I NORMALLY play a lot. The ones in the 100 count boxes are in alphabetical order. Quote Link to comment Share on other sites More sharing options...
SteveW Posted August 28, 2005 Share Posted August 28, 2005 I've always had problems keeping cards in the little slots, since my case didn't have the little plastic flap over the rows. I've since bought a case in a thrift that has the plastic flap, but I still use my original instead. For long term storage, I used to pull the grey plastic insert inside a CD jewel case out, break off the spindle/hub that the CD clicks onto, and use a Dremel handheld cutter/sander to cut a slot halfway between the top and the hub just long enough to fit the curved part of a Lynx cartridge. Pop the insert back into the jewel case, put a cartridge inside, and there you go. For the early cartrdges that didn't have the curved lip, I put a thin layer of foam inside with the shape of a cartridge cut out on the inside of the jewel case. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted August 28, 2005 Share Posted August 28, 2005 I use Nintendo BG's cart case! You can get 2 Lynx carts one of these and then just throw it in the Lynx Carrying Case. Quote Link to comment Share on other sites More sharing options...
