Shawn Jefferson Posted November 29, 2004 Share Posted November 29, 2004 Hi, I have been trying to track down source code for a high-speed SIO patch for a project I am working on, but haven't had any luck. I was hoping someone here may have some source for one they can post for me? Thanks! Quote Link to comment Share on other sites More sharing options...
cas Posted November 29, 2004 Share Posted November 29, 2004 Hi, I have been trying to track down source code for a high-speed SIO patch for a project I am working on, but haven't had any luck. I was hoping someone here may have some source for one they can post for me? Thanks! Atari Programmers Wiki -> http://www.strotmann.de/twiki/bin/view/APG...eedyLoadFastSIO Mini Speedy Handbook --> http://www.strotmann.de/twiki/bin/view/Inf...ek/MiniSpeedyCs Speedy Handbook and ROM Listing --> http://www.strotmann.de/twiki/bin/view/Inf.../SpeedyTemFifty English Version --> http://www-user.tu-chemnitz.de/~sgl/atari/...eedyhb_eng.html Carsten Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted November 29, 2004 Author Share Posted November 29, 2004 Thanks for posting that, Carsten, however, it seems that this would only work with the Speedy drives, since I cannot download any code from a happy drive, or more importantly APE/SIO2PC ? I didn't see any code that actually patches the OS there, just code to download the high-speed driver from a speedy drive. Quote Link to comment Share on other sites More sharing options...
cas Posted November 29, 2004 Share Posted November 29, 2004 Thanks for posting that, Carsten, however, it seems that this would only work with the Speedy drives, since I cannot download any code from a happy drive, or more importantly APE/SIO2PC ? I didn't see any code that actually patches the OS there, just code to download the high-speed driver from a speedy drive. Hello Shwan, that's right. I will download and disassemble the Speedy Driver and will post the SOurcecode on the Wiki. It would be nice if APE and SIO2PC would support these SIO Commands. AtariSIO ( http://www.horus.com/~hias/atari/ ) for Linux already supports these commands. If you download the latest Source, look into highspeedcode.src This should be the Speedy High Speed SIO Driver Code in 6502 Assembler. It's GPL'd code, be aware if your code has a different license. Best regards Carsten Quote Link to comment Share on other sites More sharing options...
cas Posted November 29, 2004 Share Posted November 29, 2004 SIO High Speed Driver Used by ABBUC HDI Driver (Erhard Puetz). This is the HDI OS ROM Listing Part. http://www.strotmann.de/twiki/bin/view/APG...HdiHighSpeedSio Best regards Carsten Quote Link to comment Share on other sites More sharing options...
cas Posted November 29, 2004 Share Posted November 29, 2004 Full HDI OS ROM Sourcecode http://www.strotmann.de/twiki/bin/view/APG/HdiSource HDI - High-Density Disk Interface The interface for connecting up to 4 standard drives to the XL/XE. Here you can mix 3,5" and 5,25" floppies at will. Required is that the drive supports the Disk Change signal at pin 34 of the Shugart bus. It doesn't support Medium Density (128 bytes/sector in MFM mode and 1.2 MB drives). Maximum transfer rate: 500 Kbit/s (1.44 MByte disks). The HDI is designed, build and all Source written by Erhard Pütz, (aka ABBUC Floppy Doc, Atreju). Best Regards Carsten Strotmann Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted November 30, 2004 Author Share Posted November 30, 2004 Ok, I did some experimenting using this code as a basis. When I send the $3F (get high speed index) command to the drive, where does it return the speed index? DSTATS? http://www2.asw.cz/~kubecj/asio.htm This page is confusing, it shows a table with the speeds and two columns command and data. What does that mean? Quote Link to comment Share on other sites More sharing options...
cas Posted November 30, 2004 Share Posted November 30, 2004 Ok, I did some experimenting using this code as a basis. When I send the $3F (get high speed index) command to the drive, where does it return the speed index? DSTATS? http://www2.asw.cz/~kubecj/asio.htm This page is confusing, it shows a table with the speeds and two columns command and data. What does that mean? Data send back from Floppy will always stored in the memory location pointed to by DBUF = $304/$305 So you decide where the SIO Handler will store the information. The different floppy types use different speed for Data frames and command frames. Some floppies (US Doubler/Speedy) will send Command Frame and Data Frame in High Speed. XF551 will send Command Frame in normal Speed ($28) and Data in High Speed ($10).. Because of that it is good to load the High Speed SIO Driver from the Floppy instead of writing a bulky driver that includes code for all possible combinations. Best regards Carsten Strotmann Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted December 1, 2004 Author Share Posted December 1, 2004 A question for anyone who might know: When you send $3F to APE, what speed index should it respond with? I haven't gotten anywhere with this code unfortunately. I can't seem to grok what it is doing with the table.... it seems to store a 1 into the DUNIT index of the table (8 bytes in the table) when it seems to me that it should be storing the speed index there shouldn't it? Also, you put your speed index number into AUDF3 right? The code seems to do that in the SIO handler, but how that value get there is beyond me. Also, using this code, as is, doesn't work for me at all.... it does all sorts of wierd stuff, like trying to format D3 as ultraspeed, changing the DUNIT to 8, etc... very wierd. I guess I will have to disassemble another high-speed sio driver and try to figure out what it is doing. Quote Link to comment Share on other sites More sharing options...
cas Posted December 1, 2004 Share Posted December 1, 2004 Hi, I found this sourcecode of the BiboSoft Sector Copy distributed with the Speedy http://www.strotmann.de/twiki/bin/view/APG...riSioSectorCopy In the file DSKSYS there are routines to check for High Speed Drives and an universal HighSpeed Sio Routine. All comments are in german, I'll try to translate tomorrow the High Speed parts. Best regards Carsten Quote Link to comment Share on other sites More sharing options...
Shawn Jefferson Posted December 2, 2004 Author Share Posted December 2, 2004 Thank you! For some reason this code seems easier for me to understand, even with the German comments! I'll try it out as soon as possible and see if I can get it working with my project. Thanks for your help with this! Quote Link to comment Share on other sites More sharing options...
cas Posted December 2, 2004 Share Posted December 2, 2004 Thank you! For some reason this code seems easier for me to understand, even with the German comments! I'll try it out as soon as possible and see if I can get it working with my project. Thanks for your help with this! I have translated parts of the source and attached an ATR and the Assembled Version of the Sector Copy to test it with your floppies. Best regards Carsten Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted December 2, 2004 Share Posted December 2, 2004 and if you want to have music while loading...check out http://atariarea.histeria.pl/forum/viewtop...opic.php?t=2478 Quote Link to comment Share on other sites More sharing options...
