Room 34 Posted January 8, 2005 Share Posted January 8, 2005 (Yes, that apostrophe's in the right spot.) Last year I "shelved" my original 4-switch 2600 from 1982 because the left difficulty switch had stopped working. I move to primarily using a Sears 6-switch I had acquired about a year before, because it was in pristine condition (not that I wanted to trash it, but I figured it would work reliably). Last night during the gaming festivities I mentioned in another thread, I discovered that the right difficulty switch on this unit is also flaking out! So, if this has been discussed in another thread or an article somewhere, point me to it. Otherwise, does anyone have suggestions on dealing with faulty difficulty switches, both the kinds on the 4- and 6-switch models? (The 6er's switch is not completely dead... just temperamental. If you wiggle it to JUUUUUST the right spot it MIGHT stay on "novice" mode for the entire game. I don't care how much of an "expert" you claim to be, the "A" setting on Kaboom! is madness!!!!) Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted January 8, 2005 Share Posted January 8, 2005 So, clean them. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted January 8, 2005 Author Share Posted January 8, 2005 Right... that's what I want some advice on; how do you clean them? Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted January 8, 2005 Share Posted January 8, 2005 Right... that's what I want some advice on; how do you clean them? Personally, I use a syringe and drip 2-3 drops of isopropyl (sp?) alcohol underneith the sliding part, directly onto the contacts. Then move the switch back and forth for about 20 seconds and that usually does it. Quote Link to comment Share on other sites More sharing options...
Room 34 Posted January 8, 2005 Author Share Posted January 8, 2005 Cool, thanks... I will try that. I assume you do this with the case disassembled. (I'm not afraid of that; I've opened them up before... I'm just a little shellshocked right now after tonight's iBook experience...) Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted January 8, 2005 Share Posted January 8, 2005 Cool, thanks... I will try that. I assume you do this with the case disassembled. (I'm not afraid of that; I've opened them up before... I'm just a little shellshocked right now after tonight's iBook experience...) Yes, you have to take the lid off. Quote Link to comment Share on other sites More sharing options...
