+MrFish Posted February 4, 2005 Share Posted February 4, 2005 Hi Everyone, I needed some help in finding an old machine language subroutine, if possible. It was a listing in: Compute! Issue 91 - December 1987. The routine was very useful for manipulating playfield graphics in any mode. If anyone could help in getting a copy of the listing, or direct me to a suitable alternative, it would be much appreciated. Thanks, MrFish Quote Link to comment Share on other sites More sharing options...
+MrFish Posted February 5, 2005 Author Share Posted February 5, 2005 Forgot to say, the routine was for Atari 8-Bit/Basic. Thanks, MrFish Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted February 5, 2005 Share Posted February 5, 2005 1000 REM D=USR(ADR(GP$)+GET,X,Y,WIDTH,LENGTH,BYTES PER ROW,ADR(IMAGE$)) 1010 REM D=USR(ADR(GP$)+PUT,X,Y,WIDTH,LENGTH,BYTES PER ROW,ADR(IMAGE$),CMD) 1015 REM COPYRIGHT 1987 COMPUTE! PUBLICATIONS, INC. ALL RIGHTS RESERVED 1020 DIM GP$(244):FOR I=1 TO 244:READ CODE:GP$(I,I)=CHR$(CODE):NEXT I:LET GET=0:LET PUT=0:RETURN 1021 DATA 104,56,233,6,133,227,104,133,215,104,133,214,104,133,217,104 1022 DATA 133,216,104,104,133,218,104,104,133,219,104,133,221,104,133,220 1023 DATA 104,133,223,104,133,222,165,227,201,0,240,4,104,104,133,224 1024 DATA 169,0,133,212,133,213,165,88,24,101,214,133,225,165,89,101 1025 DATA 215,133,226,162,0,228,216,240,32,165,225,24,101,220,133,225 1026 DATA 165,226,101,221,133,226,165,216,56,233,1,133,216,165,217,233 1027 DATA 0,133,217,169,0,201,0,240,220,228,217,240,6,169,0,201 1028 DATA 0,240,214,162,1,160,0,196,218,240,81,165,227,201,1,208 1029 DATA 55,165,224,201,1,208,22,177,222,201,0,240,10,177,225,201 1030 DATA 0,240,4,169,1,133,212,177,222,201,0,240,20,165,224,201 1031 DATA 1,240,10,177,225,201,0,240,4,169,1,133,212,177,222,145 1032 DATA 225,200,169,0,201,0,240,191,177,225,201,0,240,6,169,1 1033 DATA 133,212,177,225,145,222,169,0,201,0,240,229,228,219,240,35 1034 DATA 160,0,165,222,24,101,218,133,222,165,223,105,0,133,223,165 1035 DATA 225,24,101,220,133,225,165,226,101,221,133,226,232,169,0,201 1036 DATA 0,240,191,96 Notes: The variables GET and PUT (holding the starting location for each operation) are really the same, they are initialized at zero...but are included in USR commands so that you can see at a glance which operation is being done when debugging. X=the horizontal byte offset from the left border of the object you wish to GET or PUT. For GTIA graphics modes, divide the number of pixels by 2 (2 pixels per byte)...4-color modes divide by 4, and single color mode divide by 8. Y=vertical starting pixel from the top border WIDTH=the width in bytes of the image to GET or PUT. The number of pixels divided by how many fit in a byte (described above). LENGTH=the vertical size in pixels BYTES PER ROW=the number of bytes per scanline for the corresponding graphics mode... GR.0 = 40 GR.1 = 20 GR.2 = 20 GR.3 = 10 GR.4 = 10 GR.5 = 20 GR.6 = 20 GR.7 = 40 GR.8 = 40 GR.9 = 40 GR.10 = 40 GR.11 = 40 GR.12 = 40 GR.13 = 40 GR.14 = 20 GR.15 = 40 ADR(IMAGE$)=the buffer area to hold the object data that is being moved. It should be DIMensioned as the maximum WIDTH x LENGTH you will be using. CMD=Used only for PUT commands. When 0, the image placed will overwrite any previous data. When 1, existing data will be allowed to show through any "holes" in the picture (i.e. pasting w/transparancy). The value returned by a USR/GET will be 0 if no pixels existed from the area, 1 if there were. When performing USR/PUT, this value will be 1 if there was already pixels in the area where you placed the buffer image to. The program is under a page of space and totally relocatable (which means that Page 6 would probably be a good candidate to store the routine if your program does any multiloading). Otherwise, you can just GOSUB 1020 to initialize the routine and place it into the string GP$. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted February 5, 2005 Author Share Posted February 5, 2005 Many thanks Sheik! Quote Link to comment Share on other sites More sharing options...
