+KaeruYojimbo Posted February 17, 2005 Share Posted February 17, 2005 I just pulled my 2600 junior out of storage only to be reminded why it was in storage in the first place. The reset button doesn't work. Is this something that can be fixed fairly easily? Thanks fort he help. Quote Link to comment Share on other sites More sharing options...
Mindfield Posted February 17, 2005 Share Posted February 17, 2005 That sort of depends on your definition of "easily." In all probability either the momentary switch inside is dead or one or more of the solder joints connecting it to the PCB is cracked. At the very least you're probably looking at reflowing the solder joints to re-close the circuit. At worst, you'll have to replace the reset switch. It's a fairly cheap fix. Either way it's either that route or just pick up another Jr. model, which is also fairly cheap. Quote Link to comment Share on other sites More sharing options...
Stingray Posted February 17, 2005 Share Posted February 17, 2005 A broken switch is one of the easiest if not the very easiest repair you can make inside a 2600. Open it it up and take a look at what the actual problem with the switch is. -S Quote Link to comment Share on other sites More sharing options...
