Dan Iacovelli Posted February 18, 2005 Share Posted February 18, 2005 I just got a tv tuner card for my PC, I am wondering if it's possible to connect the 2600 to it(Ithink theres a coax connection on the card). If it is possible it might push me ahead on my 2600 programing(testing it on a real system using a supercharger on the 2600(ie make the bin then turn to wav file and play it thru my speaker connected to my supercahrger on 2600) any thoughts Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 18, 2005 Share Posted February 18, 2005 I used to use it but the interference was too bad to be used. But, once I did my a/v mod to my atari, nothing's better than playing atari as your desktop while listening to music Quote Link to comment Share on other sites More sharing options...
A.J. Franzman Posted February 18, 2005 Share Posted February 18, 2005 Yeah, if your video card has composite video in (or even better, S-Video) you'll get a much better picture if you modify your console to match that than to use the RF connection + TV tuner. I'm just finishing up development of a new composite mod that should have quality near or better than that of the CD4050 mod, but without the CD4050 chip (and no, it's not the version where you replace the CD4050 with jumper wires). It will have exactly the same colors as the RF out, no sync problems, and will not have or need any adjustments other than a possible slight tweak to the chroma delay pot that's already on the 2600 boards. I'm including the option to make use of the TIA blanking signal from pin 6 that is unconnected on most (all?) 2600s, which may improve brightness and sync for some users. Quote Link to comment Share on other sites More sharing options...
keilbaca Posted February 18, 2005 Share Posted February 18, 2005 I am extremely interested in the a/v mod, right now i'm just running a 680ohm resistor on pin 5, 220ohm on pin 7 and a 1kohm on pin 8 on my jr. The quality is there, just dull white vertical lines going down the screen that I'd like to get rid of. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 19, 2005 Share Posted February 19, 2005 I just got a tv tuner card for my PC, I am wondering if it's possible to connect the 2600 to it(Ithink theres a coax connection on the card).If it is possible it might push me ahead on my 2600 programing(testing it on a real system using a supercharger on the 2600(ie make the bin then turn to wav file and play it thru my speaker connected to my supercahrger on 2600) any thoughts I use a capture card to display output from my Atari running my proggies on a Krokodile Cart. It's the only way I do all my development these days (since emulators don't handle the bankswitch mode I use). I find that the quality of picture depends on where I snake the RF cable -- but it's really quite good overall, and the best thing is I can direct-capture MPG files through the video card software. Nice! In summary, compile, download through serial to KK, power-cycle the '2600, see the result on my desktop in a window displaying actual output from an actual '2600. Can't be beat Cheers A Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted March 8, 2005 Author Share Posted March 8, 2005 sucess, after a couple of tries I found that the brightness on card was default to dark pic(in the center) had to adjust itand now Ican play and test 2600 on the actual system (plus I still keep it connected to my tv to see it play on an actual tv) now I just have to move my 2600 to computer to plug in the supercharger and my advdantures in programing will begin. Quote Link to comment Share on other sites More sharing options...
shep Posted March 8, 2005 Share Posted March 8, 2005 I've always wanted a capture card to hook up all my consoles to my computer, but I was always concerned if there was any kind of lag at all...anyone had experience with any lag? Quote Link to comment Share on other sites More sharing options...
Atariman Posted March 8, 2005 Share Posted March 8, 2005 the last time I tried a game out on my ATI All-In-Wonder 8500 card, there was some odd lag. I can't remember if the video lagged the audio or the other way around. All I know is that something just wasn't quite right... I never did find any information about the problem. Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted March 8, 2005 Author Share Posted March 8, 2005 for those wondering what tv card I have: it's a WinTV-go card(it's a cheap model but it works) Quote Link to comment Share on other sites More sharing options...
tr3 Posted March 8, 2005 Share Posted March 8, 2005 it should work well Quote Link to comment Share on other sites More sharing options...
tr3 Posted March 8, 2005 Share Posted March 8, 2005 uhm sorry i didn't read that it works to you Quote Link to comment Share on other sites More sharing options...
Osbo Posted March 9, 2005 Share Posted March 9, 2005 for those wondering what tv card I have: it's a WinTV-go card(it's a cheap model but it works) I have the same card, I used it to transfer VHS tapes to the computer. Quote Link to comment Share on other sites More sharing options...
Dan Iacovelli Posted March 9, 2005 Author Share Posted March 9, 2005 for those wondering what tv card I have: it's a WinTV-go card(it's a cheap model but it works) I have the same card, I used it to transfer VHS tapes to the computer. it can be used for that too. Quote Link to comment Share on other sites More sharing options...
