pmpddytim Posted February 20, 2005 Share Posted February 20, 2005 Well I tried to run my Kroko cart with my built in serial port and could not get it to work so I purchased a usb to serial adapter. I installed all the software etc but it still wont detect the cart when I open up the Commander software. I have a working powersuply and the most recent Commander software. I'm running Xp Pro. When I run a serial port monitor I get this message Port opened by process "Krokodile Commander.exe" (PID: 3856) 01 02 .. Port closed Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
+Andrew Davie Posted February 21, 2005 Share Posted February 21, 2005 Well I tried to run my Kroko cart with my built in serial port and could not get it to work so I purchased a usb to serial adapter. I installed all the software etc but it still wont detect the cart when I open up the Commander software. I have a working powersuply and the most recent Commander software. I'm running Xp Pro. When I run a serial port monitor I get this message Port opened by process "Krokodile Commander.exe" (PID: 3856) 01 02 .. Port closed What are the specs of your power supply. Is it the correct polarity? Have you checked, or are you assuming so? Do you have the KK plugged into the '2600 *and the '2600 turned on* when you are trying to connect? Cheers A Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
